Can heated gear use the accesory switch on an 09 Street glide
Old Dec 4, 2009 | 02:18 PM
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Default Can heated gear use the accesory switch on an 09 Street glide
A new Gerbing heated liner is arriving tomorrow. Can the factory accesory switch be used to power it, if yes how would it be done?
Old Dec 4, 2009 | 02:23 PM
07RoadHawg's Avatar
07RoadHawg
Yes it can, however the best way is to wire directly to the battery. There is a 4 pin plug in front of the battery (on 2007 models at least). One of the pins is ground, and one of them is wired to the switch. The other 2 are used for a tourpak if you need them.
Old Dec 4, 2009 | 04:24 PM
Beeracuda's Avatar
Beeracuda
I also just wired mine to the battery. I've got the pigtail coming out in front of the seat. Works for me.
Old Dec 4, 2009 | 06:48 PM
Oldman Harley's Avatar
Oldman Harley
Your liner will come with a battery pigtail and an inline fuse. I recommend using it. I have mine wired so the connector comes out just in front of the seat. Oh and don't be a cheap *** and get the thermo controller with it, you will use it alot --way easier than unplugging and plugging back in or just using an on/off switch.
Tim
Old Dec 4, 2009 | 07:10 PM
itsaw0rkinpr0gre$$
"Seeker of Freedom"
I did get the single themal control for now, probably should have got the double.
Old Dec 4, 2009 | 07:20 PM
2003Springer's Avatar
2003Springer
+1 on the above
Old Dec 4, 2009 | 07:57 PM
'05Train's Avatar
'05Train
Same here.
Has anyone installed one of the permanent controllers into the fairing? That'd probably be a lot easier to use than fumbling with the controller hanging on a jacket.
Old Dec 4, 2009 | 08:40 PM
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Originally Posted by rthomp159
Same here.
someone on here has mounted it to one of the blank switch plugs on the fairing cap. they had some pics, but I can't remember which thread it was.
Old Dec 4, 2009 | 08:47 PM
'05Train's Avatar
'05Train
The permanent mount has two separate dials to control the two zones, so I'd be interested to see how he mounted them.
Old Dec 4, 2009 | 08:53 PM
itsaw0rkinpr0gre$$
"Seeker of Freedom"
It may have been in the DIY section
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
