clutch hub removal question
Old Dec 20, 2009 | 10:58 PM
fairplay's Avatar
fairplay
Default clutch hub removal question
evo / shovelhead inner primary removal. I can not get the clutch hub off. I dont know anybody that even uses the HD clutch hub removal tool, so I know it can be done.
Old Dec 20, 2009 | 11:02 PM
hog-doc's Avatar
hog-doc
A pry bar behind the hub and a light tap on the end of the main shaft with the nut covering the threads will usually pop it off.
Old Dec 20, 2009 | 11:11 PM
fairplay's Avatar
fairplay
I have already tried putting the spring tension plate back on the htree studs and using a 1/2 bolt and washerson the inside to push off the hub nut (hub nut only on the threads a bit to protect them). this didnt do much moving. Perhaps i"ll try thr hammer trick in the morning.
Old Dec 20, 2009 | 11:58 PM
2nd Mike's Avatar
2nd Mike
It comes right off if you remove the c-clip from the shaft.
Granted you'll have to depress the fingers of the spring plate to do so.
I fabbed one out of a couple of short pieces of 1-1/2" angle iron with a piece of 3/16" flat bar(welded together) and a bolt with washers to press the plate down.
It took less than an hour to fab the tool..........30 seconds to remove the hub after the "tool" cooled!
Old Dec 21, 2009 | 12:12 AM
fairplay's Avatar
fairplay
theres no c-clip. Just a hub nut and a lock tab washer.
rickncovington
Mar 3, 2021 07:59 AM
fairplay
Shovelhead
Feb 7, 2010 12:24 PM
skeyediver
Oct 13, 2008 10:29 PM
Pidgin
Apr 29, 2008 01:30 PM
antoniov1
Shovelhead
Dec 18, 2006 10:53 PM
