Heated gloves
Old Dec 24, 2009 | 05:02 PM
strtarrow's Avatar
strtarrow
Are they waterproof? IOW, say I ordered a size medium and thew are tight. Can I submerse them in water and expect to get marginal stretch should they be too tight?
Old Dec 24, 2009 | 05:19 PM
D2R's Avatar
D2R
Originally Posted by strtarrow
Another question. Does the connection come with the gloves? I found these on ebay but it states nothing about connections.
http://cgi.ebay.com/ebaymotors/NEW-G...Q5fMerchandise
I'd go to your local dealer and try them on.The Harley gloves are made by Gerbing.If that's not possible The Gerbing website tells you how to measure.I can fit into a large glove,tight fit so have the xl.You'll get the basic harness, fused pigtail,but the controller is a must about 69.00 for the single controller which I use for the gloves and jacket liner.They get way too hot without any adjustment,even here in Wyoming.I'd go directly through a dealer or online so you make sure you get the lifetime warranty.I've never had any problems,the wire's have been known to break and Gerbing's supposed to have very good customer relations and back up their product.The jacket liner works great also,bet you'll want it somewhere down the line.I pack mine all year long and have used them in every month except July and August here in the Rockies.Heated gears nice because it takes up very little room in my Tour pak and I'm prepared for any weather.
Old Dec 24, 2009 | 05:32 PM
D2R's Avatar
D2R
[QUOTE=D2R;6003507]I'd go to your local dealer and try them on.The Harley gloves are made by Gerbing.If that's not possible The Gerbing website tells you how to measure.I can fit into a large glove,tight fit so have the xl.You'll get the basic harness, fused pigtail,but the controller is a must about 69.00 for the single controller which I use for the gloves and jacket liner.They get way too hot without any adjustment,even here in Wyoming.I'd go directly through a dealer or online so you make sure you get the lifetime warranty.I've never had any problems,the wire's have been known to break and Gerbing's supposed to have very good customer relations and back up their product.The jacket liner works great also,bet you'll want it somewhere down the line.I pack mine all year long and have used them in every month except July and August here in the Rockies.Heated gears nice because it takes up very little room in my Tour pak and I'm prepared for any weather.i believe the inner liner is water proof.They recomend treating the leather outer.I wouldn't recomend submersing them and stretching them out.Make sure you order the right size.
Old Dec 24, 2009 | 05:50 PM
OhioSkully's Avatar
OhioSkully
check out heated gear outlet.com have gerbing for about 75% off when iam ready to order ill be looking at there site.
Old Dec 24, 2009 | 06:26 PM
harley0711's Avatar
harley0711
I ONLY wear and use Gerbings... I just bought several items from
http://www.grandprixmotorsports.com/...mit_n.more.htm
Not sure if the sale is still going on or not BUT = 20% off and FREE shipping...
I stocked up on seveal items, evean got back ups..
Old Dec 24, 2009 | 08:18 PM
Twinrider's Avatar
Twinrider
I can guess a decent pair are worth the coin but what are the best, what can one expect to pay and most importantly, just how do they work, meaning how do they hook to a power source? I will ride in anything above 30 degrees but my fingers are the first to go and I have to pull over, set my gloves at the engine to warm them and rub fingers across the heads.
If you don't have a heated jacket get that first. Your body reacts to getting cold by cutting off the blood to your extremities and increasing blood flow to your vital organs. Which is why your hands get really cold first.
A heated jacket will keep your core very warm, and in turn, your body will increase the flow of warm blood to your hands, keeping them much warmer. You might find you're fine with just a good pair of winter gloves, like HD's FXRGs.
Check into the Powerlet stuff. http://www.easternbeaver.com/Main/El..._clothing.html
Old Dec 24, 2009 | 09:58 PM
Yokel99's Avatar
Yokel99
I have the Harley branded Gerbings liner and gloves - incredible warmth even in wet snow and rain
Old Dec 24, 2009 | 11:38 PM
BigDaddyMike's Avatar
BigDaddyMike
Look at the Tourmaster Synergy line. I bought a jacket liner AND gloves, with individual thermostats and all wiring for under $300 from Motorcycle Superstore.com. Free shipping and No tax sweetened the deal. The gear is top shelf and I am very happy with it.
10 minute hook up to the battery, hop on the bike and plug it in. If you buy the jacket liner it has wiring in the sleeves for a pair of gloves. Waterproof, machine washable and also guaranteed for life. I bought same size in gloves, one size larger in jacket beacuse they are cut tight. You want the jacket snug to transfer maximum heat.
Old Dec 25, 2009 | 01:25 AM
Jukebox's Avatar
Jukebox
I have been saving my coin so as to buy a set of gloves for the wife and I both,but a friend of mune came riding up monday with some handlebar mittens the other day. They may look funny but they only cost $25 and they keep the wind off of your hands and you don't have to wear as thick gloves. No more cold weather than we have here these things are perfect. I now have engine guard chaps and with the handlebar mittens I can pull all my winter gear off in less then 15 minutes.
Old Dec 25, 2009 | 01:34 AM
Twinrider's Avatar
Twinrider
I use these as well in winter. Together with heated grips I'm set for commuting.
