need help w/ 2000 flhri
Old Dec 30, 2009 | 11:11 AM
INKANDBIKES's Avatar
INKANDBIKES
3rd Gear
Default need help w/ 2000 flhri
Hello all. I have a stock flhri with only hooker tuned flow slip-ons. I am installing a arlen ness stage 1 big sucker over the weekend. After i installed the hookers it was running rich still, will installing the air kit help lean it out? Also can i have my bke be adjusted with out going to say a power commander or do i need to run a power commander or like systems to be able to fine tune my rk? I am also thinking about getting the full sac true dual kit, does anybody on here have it? Any complaints about them? Tthanks for your time.
Old Dec 30, 2009 | 11:41 AM
dawg's Avatar
dawg
I'm assuming you have EFI, yes? Once you install the A/C you should get some sort of tuner. Is yours a MM system or Delphi? Delphi has been easier to work with than the Magnetti Marelli but, nonetheless, you should get a tuner. You can load canned maps and get real close, or you can have it tuned to get spot on. Several here run the Fullsac kit and seem to like it.
Old Dec 30, 2009 | 12:07 PM
INKANDBIKES
3rd Gear
Yes it is efi I have the mm system.
Mark Almond
Aug 6, 2018 08:36 PM
rietherll
Jun 17, 2011 11:43 PM
anonymous_1
23
Oct 23, 2010 11:03 AM
Dakotazeb
Aug 2, 2005 12:33 PM
JBBOOKS
Exhaust System Topics
Apr 17, 2005 02:08 PM
