How is a headlight mounted in a stock Ultra Classic fairing?
Old Jan 6, 2010 | 07:31 AM
shortride's Avatar
shortride
Default How is a headlight mounted in a stock Ultra Classic fairing?
I'm thinking about converting my RKC to a full dresser and wanted to know before I get into it just how much works it's going to be. Other than figuring out the wiring, I would imagine mounting a stock Ultra Classic fairing will be the most difficult. I've got a factory service manual but it doesn't show a procedure for conversions. I'm not sure following the instructions on removing everything from the King Classic is going to be enough instructions. A lot of these instruction assume you are an experienced Harley tech. Does anyone have a parts list for all of the components for mounting a fairing? Any help will be appreciate and it will help me decide if I want to get that involved.
Old Jan 6, 2010 | 07:47 AM
Cyphilis's Avatar
Cyphilis
One option to think about, just adding an aftermarket fairing. Its like changing out your windshield,.. fast and easy. Turning a RKC into an Ultra would be a headache. You would be surprised at how much stuff is crammed behind that fairing.
Old Jan 6, 2010 | 07:52 AM
shortride's Avatar
shortride
Thanks for the input but I'm not much into aftermarket applications. I've always like the stock look even if it's not factory. I wasn't planning on doing a main harness replacement, just the inner and outer fairing with a stock radio and harness without handlebar controls and no gauges.
Old Jan 6, 2010 | 07:54 AM
jimsflh's Avatar
jimsflh
No disrespect intended, but why an ultra fairing? There are after market batwings that have room for your stereo, and don't have holes for your speedo that in on your tank? Most likely will be easier to mount and make work with your FLHR.
Old Jan 6, 2010 | 07:58 AM
jimsflh's Avatar
jimsflh
oops see another brother was thinking the same and hot post before me! LOL
Old Jan 6, 2010 | 08:08 AM
k&j eglide's Avatar
k&j eglide
As far as I can tell, the only differance between an Ultra and any other Electraglide, such as police model, would be filler panels or pieces for items not installed, such as a radio. By far the best option is going to be swap meet parts. Every time I go to the swap meet there's a guy selling touring bike fiberglass parts-outers, inners, bags, etc. Probably going to be some paint costs too. The aftermarket kits I've seen are mostly to add a batwing fairing to something other than a touring front end. The front end geometry for Softails is different than touring frames and therefore requires modifed parts and mountings. As you already have a touring front end, factory parts are your best bet. I also don't think that the light is actually mounted to the fairing outer, rather the outer is a shell that fits over. You will likely have to remove the cover on your light, but even a total replacement should be fairly inexpensive. BTW, a friend of mine is looking at adding a fairing to his Fatboy, and the aftermarket kits are all around $1400.
Old Jan 6, 2010 | 08:09 AM
DoomBuggy's Avatar
DoomBuggy
The headlight itself is mounted to the fairing so that part is taken care of for you. Next you need the mounts from the fairings to the legs. The radio mount is integrated with the fairing mounts so that is straightforward as well. The harness would actually not be too bad, and if you are going to go the stock route the controls on the bars are a blessing. I am not sure how your ignition switch is set-up, on the Ultra it is integral to the fork locks with a bezel that goes around it and also mounts some of the switches.
There are a lot of little parts, but the swap should not be too hard.
Having said all that I also would be more tempted to go with an aftermarket. That would make it easier to switch back to stock if you ever wanted to.
Old Jan 6, 2010 | 09:06 AM
shortride's Avatar
shortride
That's ok. No disrespect understood. I'm doing this only because I like the Ultra Classic and if I can't do it like an Ultra Classic, I'm not doing it. I just don't like aftermarket except where there are absolutely no options. I know that may not be easy to understand but I will most likely put smoked mirrors in place of the gauges. I'll use the Ultra Classic ignition/fork lock switch strictly for a fork lock. It would be a lot easier for me to just buy an Ultra Classic. My problem is, I can't afford one. Doing it this way, I can collect everything I need over a period of time without being out the expense all at once. Other than not having the money, my biggest problem is, I always want to do it now. I only have a limited budget for my toys and that's a large restraint. If I have to sell my RKC and do without riding for a while in order to buy an Ultra Classic, then I would be without a ride for a very long time. I owe to much on my RKC to have enough equity for a trade or to sell out-right. So, that's it in a nut shell.
I also appreciate input from DoomBuggy as well. Thanks!
Old Jan 6, 2010 | 05:48 PM
robbie52's Avatar
robbie52
I bet the cost of the fairing, radio, guages, headlight assembly, and all of the brackets would shock you. Guess $5500.00??? Don't have a clue.
Old Jan 6, 2010 | 06:08 PM
ddm502001's Avatar
ddm502001
My choice was a detachable, I did not want to go through changing the nacelle to the ultra/electra equipment as I wanted dual purpose bike.
Attached Thumbnails How is a headlight mounted in a stock Ultra Classic fairing?-my-03-003.jpg   How is a headlight mounted in a stock Ultra Classic fairing?-my-03-001.jpg
