Rev Xtend feature?
Old Jan 11, 2010 | 10:19 PM
Mountainkowboy's Avatar
Mountainkowboy
Thanks for the info.
Old Jan 23, 2010 | 08:35 PM
oneillto1's Avatar
oneillto1
Just another confirmation of previous posts. Since my engine build (08 Ultra), I've been revving the motor a lot more. I have also noticed the tach needle stops just above 5,000, but continues to rev to redline. Needless to say, I've hit the rev limiter a few times!!
Old Jan 23, 2010 | 08:46 PM
harleytuner's Avatar
harleytuner
The rev limiter the ECU uses runs off the tach, so in order for PC to use rev x-tend the had to confuse the ECU to think that the engine isn't hitting the stock 5500 limit, so PC interupts the tach signal and stops the tach at 5000 - 5100 RPM's and takes over the limit. It's good in the fact that you can get higher RPM's but it sucks for racing or serious performance riding because you don't really know exactly where you are untill you hit the limit. By that time you are a split second late in shifting. no big deal unless you are racing or at the drag strip or something.
Old Jan 23, 2010 | 09:02 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Not exactly but you have the general idea. The stock rev limiter is a programmed function of the calibration. On drive by wire models the PC drives the crank signal above 5100 RPM's and clamps the signal and because the tach is wired off this circuit it stops at approx 5120 RPM's.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jan 24, 2010 | 12:12 PM
riglide's Avatar
riglide
i find it is alittle strange when running with other people took pc out will try something else like an accurate tach signal.
Old Jan 24, 2010 | 01:05 PM
harleytuner
Got it thanks. Basically PC has to trick the ECU to think it's not getting above 5100 RPM's. I was in the mind set that the ECU got the signal from the tach for some reason. but I hear what you are saying, makes sence to me.
Old Jan 24, 2010 | 07:37 PM
papifun's Avatar
papifun
Jamie -I have the Stage1 download from HD with the PCV - should i have the revlimit in PC software with a check or not ?
Old Jan 24, 2010 | 08:28 PM
harleytuner
If you want your bike to rev to 6250 RPM check the box, if not leave it unchecked. It's not really a setting you have to have checked or not, it's a preference. I personally don't like the fact that the tach stops at 5100 or so RPM's and the bike keeps revving up. If you are "performance" riding you want to shift right before your bike hits the limiter, but when you can't see the tach it can be difficult. Just seems like a half assed way to get by the factory settings. I personally like my SERT, I raised my rev limiter to 6500 and my tach goes there.
Old Jan 24, 2010 | 08:37 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
If you have a stage 1 download you do not need to check the Rev Xtend.
heavymetalthunder
The Dyno Room
14
Nov 7, 2016 09:26 AM
Flintshooter54
Nov 28, 2015 07:41 PM
Glyder
Jun 1, 2011 08:53 PM
lfalla
Aug 2, 2010 07:23 PM
Magos
Apr 3, 2009 06:19 PM
