check your wireing!
Old Jan 8, 2010 | 06:42 PM
twodollarbill's Avatar
twodollarbill
If you ever bought saddlebags had to relocate your rear turn signals on a softtail or sportster,
you know there is not much room for your fingers between the rear tire and the inner fender.
I'm amazed there is not more problems there.
Old Jan 8, 2010 | 09:34 PM
RKKY's Avatar
RKKY
Had the same thing happen on my old Road King. Ended up re-wiring the *** end and using on of the newer adhesive conduits. Never had any problems after that.
Old Jan 8, 2010 | 11:16 PM
ken b's Avatar
ken b
Yep, Been there too
My tail light/brake light stopped working. So I checked the fuse. It was blown. Changed the fuse tried it again. POOF, blew a fuse. Ohm checked and I was shorted to ground. Following the harness back I found that the tire wore threw the harness. Lots of bare wires. I patched it up rewrapped it and relocated the harness. All is fine now. Just thought I would share since this sounds like it might not be an isolated case.
Happend shortly after my Dealer replaced my tires. The Mechanic might have bumped the harness in the fender. Just guessing. I didn't take it back to them because it was easy enough for me to fix and just get back to riding.
Old Jan 9, 2010 | 03:48 AM
oinker02's Avatar
oinker02
Originally Posted by harley#1
I guess my dealer likes me, no problem.
Heh, heh.........
Old Jan 9, 2010 | 07:29 AM
SGLarry's Avatar
SGLarry
Hey guys. I decided to do some paint work on my 09classic so today i took off the rear fender and got quite a suprise, the wire harness inside was wore have way through bearing some wires. the combination of a lowering kit and soft shocks was the problem. I only lowered it one hole or 3/4 in. Adjusting the air shocks for me wasn't hard but 2 up with all the junk took time. I was up over 50 lbs. of air just to stop bottoming but the ride was bad.(new progressive shocks should cure the problem). Just a heads up to all.
Just a "heads up" on your "heads up" :-) You've got to be careful about using lowering blocks and/or shocks or you'll be hitting the wiring and the fender if you're not careful...replacing the wiring harness and fender ain't cheap. Here's some good info w/ a formula on how to check the correct distance between the tire and fully compressed shocks in this thread:
https://www.hdforums.com/forum/touri...ml#post5797714
Old Jan 9, 2010 | 07:30 AM
jharanin's Avatar
jharanin
Funny you say that, I was doing some paint work for a friend the night he brought the parts to my place he said the same thing "glad I pulled the thing a part, found all the wiring around the rear fender had worn thru to bare wire"...might not be a bad thing to check over the non-riding months..
oscardog1
Feb 18, 2016 02:54 AM
Mike07FLHTC
Apr 18, 2012 08:40 PM
DynaWdDawg
Aug 11, 2011 07:28 AM
hwyjunkie
Nov 18, 2007 06:45 PM
4Scott4
Dec 18, 2006 03:55 PM
