lower ultra
Old Jan 8, 2010 | 08:10 AM
pattiann's Avatar
pattiann
Default lower ultra
has anyone used those ebay 50 dollar shock lowering kits on their electra glides? want to lower a 2004 ultra one or two inches, cheap.
probably one inch will do. are they safe and can i still ride two up?
Old Jan 8, 2010 | 08:29 AM
piasspj's Avatar
piasspj
My Ultra was lowered 1" in the rear using similar blocks (sorry I don't know what brand). No problems. I run the shocks with higher air pressure for 2 up.
Old Jan 8, 2010 | 08:35 AM
soos's Avatar
soos
When you go cheap on a lowering kit, you get what you pay for. I tried a RUB kit a few years back which moved the lower mounting position of the rear shock back and down about 1". It did lower the rear but I had to increase the air pressure in my shocks to keep from bottoming out. This was without any added weight to the scoot. I found out later after taking the kit off that I was doing some serious rubbing to the wiring harness under the rear fender. IMO I would suggest doing it right and try going with a different and shorter shock as opposed to repositioning the shock that you already have.
Old Jan 8, 2010 | 08:39 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
I am yet to find a shock or air ride system for baggers that provides a ride that is the quality that I think it should be. I have tried 3 different air rides and the Harley lowering shocks. I don't waste my time with the lowering blocks. I find that the best ride has been with the stock shocks by far. I am now working on putting a heavier viscosity oil in the lowering shocks and stock shocks to see if I can get the ride any better. All of the air rides I have tried (Arnott, Tricky Air, and Platinum) have bottomed out at certain times.
Old Jan 8, 2010 | 10:02 AM
02FLHTC's Avatar
02FLHTC
I had a 02 Classic and had the lower rear shocks plus the low profile seat... helped me a lot because I am only 5'7.. no problems with my wife on the back...u do have to watch the pressure in the rear shocks..
Before I rode out of the showroom on my new 09 Ultra, I had the shocks put on and another new low profile seat...both H/D.... I'm not as low as I was before but with boots on can put both feet flat... ride seems stiffer also... no problems with wife on back..
Old Jan 8, 2010 | 10:08 AM
FLHTCU Owner's Avatar
FLHTCU Owner
+1. Everyone, and I mean everyone I've talked to that has lowered their bikes states that you will lose some ride when doing so. I'm sure you've thought of that already, but just letting you know.
Old Jan 8, 2010 | 02:18 PM
pattiann's Avatar
pattiann
might just leave it alone. dont really want to air shocks up too much
legendzzz
Aug 31, 2019 10:58 AM
Mudfoot
Jan 15, 2016 03:03 PM
easy4me
Aug 18, 2009 08:32 AM
Jazz56
Jan 18, 2008 06:51 PM
clap
Sep 20, 2005 01:33 AM
