Was going with the SE255 cams:
I am anxious for Fuel Moto to test the 6-6's with the 4° advance gear, which is supposed to shift the TQ curve to the left about 300 RPM. That would put the low-end near that of the 255's, but peak-HP would certainly take a hit.
Which is right for any given rider depends on where you want the power. I'm a member of the gang who worships the low-end and midrange while placing little priority on peak-HP (moving the TQ curve up with no shift to the right), but others may prefer to sacrifice the low-end and gain more on the top-end (moving the curve up and to the right). The first group has much less to choose from, as when stock compression is retained it is difficult to hold onto the low-end TQ with longer duration and later intake close specs, and most performance cams tend to have these characteristics. The 255's are a very odd design that obviously emphasizes low-end and midrange TQ (~10% increase) but unapologetically offers little increase in peak-HP (maybe 5% increase). It also leaves little room to grow if someday you want to make a dyno shoot-out winner, as with its mild duration and early intake close it will likely never make more than 90hp even in a 103 with 10:1 compression.
This is a good post! Thanks
You can easily recover the low-end on 6-6's by simply installing higher-compression pistons, but that takes more money, and the thrust of my points were that the 255's were a good option for those on a low budget who want an increase in low-end and midrange TQ in an otherwise stock TC96 (with Stage 1 stuff). Many of us ride between 2000-4500rpm most of the time and want more power there.
You can easily recover the low-end on 6-6's by simply installing higher-compression pistons, but that takes more money, and the thrust of my points were that the 255's were a good option for those on a low budget who want an increase in low-end and midrange TQ. Many of us ride between 2000-4500rpm most of the time and want more power there.
The other thing that you missed and you may have to go to NightRider to read it is; this enine is a low compression engine.
Another thing, Flat top pistons do not raise the compression. Compression ratios raise compression. Do you know anything about Physics?
I was showing the truth, but you can not see the truth because the truth is not with you.
that was a nice post you Quoted from Fuel Moto, inspite of the fact that you are poor salesman.
the only difference between the 96 and 95 is the stroke. Otherwise they are the same animal. A twin cam engine. You can dissect the heads but they are both twin cam engines.
Iclick, you don't know as much as you boast about. I am the producer!
My bike has stock pistons which have a top surface that could be referred to as a "flat top." The "flat-top piston" typically referenced by HD and elsewhere is an aftermarket HD item that raises the compression ratio to 10:1 in a TC103 and 9.4-9.5:1 for the TC95 using stock heads. There is no such option for the TC96. It is a term used to differentiate it from the higher-compression domed pistons HD offers. Once again, reference the SE catalog if you need more info.
TC95: Bore 3.875", stroke 4.0"
TC96: Bore 3.75", stroke 4.375"
TC103: Bore 3.875", stroke 4.375"
First, the TC96 has a longer stroke and a smaller bore than a TC95. Second, the TC88/95 is a totally different engine with few common parts compared to the newer TC96/103 design. Apples and oranges.
It would be extremely useful info for those of us considering what cam to get.
