Need some HELP!
Old Jan 10, 2010 | 12:01 PM
harley-jones's Avatar
harley-jones
Default Need some HELP!
I had a little project going and you all know how the easy things turn bad in a hurry. I broke a tap in the bracket that the rear pegs bolt to.
My question is can that bracket be removed from the bike without any problems. It look like it is just held on with two bolts and it will make it a lot simpler for me to get the broken tap out.
Here is a pic. You can see the broken tap in the bottom hole.
Thanks.
Old Jan 10, 2010 | 12:07 PM
beerguz's Avatar
beerguz
Call me crazy, but have you tried a small pair of needlnose pliers to back that tap out?
Old Jan 10, 2010 | 12:08 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
You can also use a center punch and hammer to bust the tap into easily removable chunks.
Old Jan 10, 2010 | 12:11 PM
masterblaster's Avatar
masterblaster
I would get the manual out, it looks like that braket is part of the suspension. may I ask why you were tapping that hole? Was it a Craftsman tap or HF? Did you predrill?
harley-jones
Good sugestions guy, but it is in a tight area with the rear exhaust on one side and the primary on the other and not alot of work room. It will be a lot easier if I can remove the bracket and work on the bench.
Old Jan 10, 2010 | 12:31 PM
harley-jones
I got it out! Thanks anyway guys.
Old Jan 10, 2010 | 01:04 PM
strtarrow's Avatar
strtarrow
Well, tell us how you got it out. We need to share information here!!!!
Old Jan 10, 2010 | 01:44 PM
CroK's Avatar
CroK
Pair of stout needle nose pliars and turn counter clockwise. Might have to go back and forth a bit to get it goin...
I know, he already got it, but sometimes that actually works!
Chaffeekid
Oct 28, 2016 07:08 AM
fadedbuddha
Oct 10, 2014 05:39 PM
Deepsouth251
May 16, 2009 04:24 PM
DiegoKing
Apr 6, 2008 06:43 PM
Skaarsgard
Mar 5, 2008 08:21 PM
