The thing that strikes me with this set up is that everyone seems to want to eliminate one of the front rotors and brakes to get a better view of the custom wheel. I've got to think that this is a bigger issue (stopping a big bike soon enough) as opposed to handling from the height difference on the tires.
Not to mention the chrome rotors I was looking at were more expensive than the wheel itself... jeez
OOO Boy... another nay sayer... You could upgrade your rotor to a 13" and run a 6piston caliper to make up a little on the loss of a front brake, however I ran the stock set up with only the single side on my 07 and you just get use to slowing down a sec earlier. No biggy... IMHO.
i agree i cant tell abit of difference withone rotor and i didnt go up to the 13" either stops fine
95% of our customers who went with a 21" up front love the look and feel the handling is different but still good. I personally think a 18" front handles a little bit better than the 21" fronts but it is not a drastic difference to me when I ride them. The 21" fronts will fit the stock fender but you need to check the fender clearance and possible raise it a little. Let me know if you any other questions about this combination on your bagger.
Going back and forth on the 18 vs 21 on my Ultra, bike below is the "Play bike" Ultra was for touring and staying stock, but I cant stop the mods Whatever you decide, give Robert from Hogpro a call. Outstanding customer service (see wheels and wide swing arm kit below from HP) Robert and HP are a pleasure to deal with.
...sure, runnin' the 21 up front u definitely get some handling issues but nothing the coolness of havin it won't compensate for
+2 on Coastal Moto for the hook up on shipped Ready-2-Go rims, rotors & tires.
...the stock fender works fine, but they recommend a minor adjustment.
i went by these instructions but i also had to take a die grinder and and cut a little more out of the bottom to completely get clearance but was no big prob worked fine after that
