Another HD Cam Labor question?
Old Jan 13, 2010 | 02:15 PM
twincam47's Avatar
twincam47
The bore of a 95" and a 96" are different....
95" = 3.875
96" = 3.750
Originally Posted by harleybill2008
I just looked up the part number on James Gasket site and this is what it says :
0934-1597 FITS: 05-09 Twin Cam 95"/96" models, STYLE: .036" head gaskets $72.95
Old Jan 13, 2010 | 02:17 PM
dawg's Avatar
dawg
Originally Posted by dawg
It appears that Sonnax may be the distributor and sell Torrington/Timken bearings. If that is the case, than that is fine.
Upon further research, Sonnax does sell some Timken bearings but running that number through the system shows it as being a Sonnax brand and not Timken so I'm not sure which one it will be.
Old Jan 18, 2010 | 03:24 PM
harleybill2008's Avatar
harleybill2008
To make things simple I just bought the timken bearings myself and I will take it to the builder if I decide not to give it a go myself. Dawg, by the way, what is your recommended head gasket (size) and do you have any familarity with these copper ones? I did a google on head gaskets and came across another site talking about the copper gaskets. I did a search here but didn't really find anything about them. I have to figure they have been discussed but thought I might as well bring it up (again?). I believe it's from hemrickperformance.
Old Jan 18, 2010 | 03:33 PM
dawg's Avatar
dawg
The head gasket thickness all depends on the components such as what they are decking the heads to, etc. I generally use a Cometic .030, but if headwork is being done, I let the person doing the work know that I plan on using that so that they can compensate appropriately. Bean and Springer at Big Boyz have a new head gasket that they came out with, believe it was copper but not sure. You might want to check with them if you are interested in that one. I like the Cometic MLS one, but again you need to work that out with your person doing the headwork.
harleybill2008
DXHD $100
Jan 1, 2014 07:31 PM
ultraclassic53
Oct 30, 2012 10:46 PM
cornking
Feb 22, 2011 08:51 PM
redrott
EVO
Jul 11, 2010 08:44 AM
SICKBAGGER
Apr 4, 2010 06:32 PM
