I have looked at a few posts of getting cam work done but I have another question to add to the bunch. My local HD dealer wants about 1700.00 otd for adding a new cam (woods 7h or 8-6), cam bearing, james gasket kit, quick install pushrods, kit(valve springs), gasket for cam cover + saying 10 hours of labor (includes dyno time). They are also getting a valve job done along with Head Decking from sub contractor. These last two costs are about (162.50+78.00). Also, are they missing something that should also be included or added to this list?
I keep seeing about 4 hours for cam install plus dyno time (what is reasonable for dyno time?) Even with 3 hours of dyno, that only adds up to 7 hours. Would 3 more be due to heads and such? Seems like a lot! Dawg, if your listening(reading), what are your thoughts?
Parts costs seem reasonable but I'm a bit concerned on the labor hours involved. Is this overkill or are they making a decent deal?
Sublet machine work: valve job 162.50
Head Decking 78.00
First, don't go with the 0924-0107 Sonnax bearing. Get Timken/Torrington B168's even if you have to buy them and bring them in to them. Second, I don't know if you are trying to save cash or not, but instead of the 17997-99A pushrods I would get the 18404-08 tapered pushrods, just slightly more in cost. The added labor must be what they consider for the valves/springs and whatnot. What size head gasket is coming in that James' gasket kit? James' are good gaskets, but Cometic makes a decent kit for about the same price. I would ask how much of that labor is considered dyno time also.
Thanks D, I had asked them about the torrington bearings when they made the quote up so that's one they got me on. It's not a money thing so the tapered pushrods will be added as well. I will have to check on the head gasket size. That would not even be something I would have considered. I will ask them to break down the labor costs as well. Thanks again.
Didn't see any lifters listed in the parts breakdown.
Also, unless the dyno tuner has specific experience with your build, I'd want a minium of 3 hours dyno time to assure a complete tune, not just a tune for WOT and a dyno sheet.
Good luck with your project.
I agree. No lifters plus I don't see a new oil pump or cam plate. I'm not sure these are all necessary but they seem to popup in other cam installs and I want to make sure what's done is done right.
Stock pump and plate on the 96's will be fine for your build. Two schools of thought on the lifters, one changes when doing a cam change no matter what and others only change if the mileage is in a higher range like 20-30k.
That's what I was beginning to think as well since I haven't seen this on other posts. Dawg, what about that sonnax bearing. I was reading on another post here that it is really the torrington bearing anyway.
