All this bagger power..........
Old Jan 18, 2010 | 11:16 PM
B-1B_Guy's Avatar
B-1B_Guy
Default All this bagger power..........
Fellas,
I read almost all 160 pages of the bagger dyno post and did not see hardly any CLUTCH improvements on these high # motors. I'm knee deep in a stage 3 build on my UC and need ideas on what to do to the clutch. SE? Barnett? What do you recommend? Any help would be greatly appreciated. Thanks in advance.
Old Jan 18, 2010 | 11:20 PM
dawg's Avatar
dawg
It depends on if you NEED to upgrade the clutch. That would depend on how much tq/hp your build is going to have. Some have gotten by with an SE spring, a VPC or the like. If you need to put in a whole clutch, I'd suggest the Rivera Primo.
Old Jan 18, 2010 | 11:31 PM
B-1B_Guy's Avatar
B-1B_Guy
Dawg,
With my 103, PCV, TW-7H cams, SE Heavy Breather, true duals and Hillside stage 3 heads, I'd be shocked if I were under 100/100. With that said, will the stocker clutch handle 100/100 riding 2 up in the hills? I don't want to skimp on the clutch after spending $2K on the motor. Thanks for the info on rivera. I've heard of them and will research.......thanks again.
Old Jan 18, 2010 | 11:41 PM
dawg's Avatar
dawg
I think you could get away with the SE spring, but it will increase the pull. A variable pressure clutch (VPC) from AIM would do the trick just fine and a lot less costly than putting in a whole clutch. I used one in my 04 when I did the 95 build. LINK
Old Jan 19, 2010 | 03:03 AM
kingkingking's Avatar
kingkingking
What year is the bike? In 06 the clutch design was upgraded to 8 plate and it is pretty strong.
I am running the stock clutch with the SE spring. The SE spring is much stiffer and grabs very well. If I am a little careless and twist early I have had the motor over rev and had the clutch pull it down with just a little slip.
Your stage 3 wont trouble a post 06 clutch at all.
Old Jan 19, 2010 | 03:06 AM
grbrown's Avatar
grbrown
I still have my original 1990 clutch and fitted an S&S 107 a couple of years ago. Gives just over 100 HP/TQ. I have a Barnett spring, plus a Clutchlite to reduce lever effort back close to stock. My motor cost a lot more than $2k, but I don't see the sense of fitting a complete new clutch for the sake of it.
Old Jan 19, 2010 | 07:29 AM
lkr0's Avatar
lkr0
I have used http://www.aim-tamachi.com/home.php?cat=18 on three motors two 107's and a 103 with excellent results
Originally Posted by B-1B_Guy
Fellas,
Old Jan 19, 2010 | 12:10 PM
Biggzed's Avatar
Biggzed
SE Spring and a VPC 92T on mine.
Zach
Old Jan 19, 2010 | 06:17 PM
B-1B_Guy's Avatar
B-1B_Guy
Bike is an 09 UC. VPC looks pretty interesting. I'm going to do more homework, thanks for the ideas, really appreciate it.
Rumblin
Engine Mechanical Topics
15
Jan 29, 2017 03:22 AM
ridedaddy
Jan 2, 2015 07:05 PM
Hoblick
Jan 1, 2012 06:58 PM
I CUT 1
Exhaust System Topics
Jan 8, 2009 06:40 PM
arachman
Mar 20, 2008 08:21 PM
