Pinging issue
Old Jan 19, 2010 | 04:07 PM
kingkingking's Avatar
kingkingking
Originally Posted by timvan
Short bus?
MB have you tried to add a octane booster? Does it still ping under load?
I am running 100 octane (RON) which is about 95 octane on your scale.
It doesnt ping because I added fuel. I didnt need to back off the timing or add octane, I just added more fuel. Get it??
Old Jan 20, 2010 | 05:45 AM
timvan's Avatar
timvan
I get it completely (just dont add so much fuel as to wash the cyl), I was asking if MB had tried the additive as it would likely fix the issue until he can get it tuned on his fuel
Old Jan 20, 2010 | 05:56 PM
Dalton's Avatar
Dalton
But....you can actually start throwing too much fuel. It is a balancing act. Is the ping under full load, snap open the throttle in 6th gear at 3k? If so, it is entirely possible for an engine to ping if the timeing is too far advanced, the A/F is too lean or both. By pulling 3-5 degrees only in those cells and the cells immediately prior to when the pinging is actually recorded, it should not make the engine a "pig". I actually prefer to get the fuel where I want it for economy and adjust the timing to suit. Too much fuel can hurt economy and also hurt longevity of the engine.
Old Jan 20, 2010 | 06:55 PM
masterblaster's Avatar
masterblaster
Thanks gents, will baby it until I get these issues worked out.
Old Jan 22, 2010 | 12:00 AM
Lonewolf176's Avatar
Lonewolf176
Another thing is you are running the HQ's protuner and they do take time to dial in. How much time have you actually ridden there? I don't know if you are running a 2:1 pipe but with the 575's and a 2:1 you will see a lot of reversion at that rpm. My suggestion would be to get the bike tuned and then plug in the protuner. That will give it a chance. It may be timing, fuel or your ae table that needs to be adjusted. You just won't know until the ve tables are calibrated and the protuner has settled in. First pic is afr lines @ 40,60,80,100 TP,s after downloaded map. Second pic is after the ve tables are adjusted. Until these are straight you could be pinging @ 2750 and get 35mpg @ 3500. To me that's why any build should be broke in and tuned on a dyno asap.
Attached Thumbnails Pinging issue-reversion.jpg   Pinging issue-calibrated-ve-s.jpg
Old Jan 22, 2010 | 05:36 AM
timvan's Avatar
timvan
I think the op is running a sert
Old Jan 22, 2010 | 07:20 AM
DMJFatboy's Avatar
DMJFatboy
I had the same issue with my 07 fatboy and a real good mechanic friend of mine told me to put gas with higher octane in it. That seemed to work.
AllenW
Jun 9, 2013 01:56 PM
keno
Apr 5, 2013 11:40 AM
Fathertime500
Nov 17, 2012 07:11 AM
3/4 life crisis
Jul 24, 2011 12:27 PM
StreetGlider56
Jul 28, 2006 10:31 PM
