PC3 Questions...
Old Jul 28, 2006 | 09:53 PM
StreetGlider56's Avatar
StreetGlider56
Default PC3 Questions...
Ok I just got my PC setup in my garage, and the software installed, But when I connect
everything up, I get no data in the map area, with Ign on and start acctivated (Not running)
The RPM, Fuel, throttle change will display when running, (I asume is is supposed to),
the Power Commander has not been firmware updated for extended rev and start fuel.
Why isn't it displaying the current map? Has the Stealer disabled the PC3?
Should I get this upgraded? I'm using the new download from PC...
Has anyone had this problem? or and am I just missing something?????
[IMG]local://upfiles/11910/E2E6E499EF374E57B0F5190197114088.jpg[/IMG]
[IMG]local://upfiles/11910/EEF41859CD0646E393D18B42AC45D776.jpg[/IMG]
Old Jul 28, 2006 | 09:58 PM
bountyhunter's Avatar
bountyhunter
Default RE: PC3 Questions...
Exactly the reasons why I had my dyno guy do the PCIII install/tune![sm=helpout.gif]
Old Jul 28, 2006 | 10:06 PM
maineultraclassic's Avatar
maineultraclassic
Turn the bike off, and attach the 9v power adapter to power up the PCIIIusb. Then open up the PC software on your computer, and you will be able to change or work with the map installed on the PCIIIusb.
Not sure why it works that way............but it does.
Steve
Old Jul 28, 2006 | 10:22 PM
StreetGlider56
I'll go and pick up a 9 volt adapter tommorrow, The instructions say it will work on or off the bike...
Old Jul 28, 2006 | 10:26 PM
KansasHog's Avatar
KansasHog
Mine came with it in the box.
Old Jul 28, 2006 | 10:31 PM
jkoch09ultra's Avatar
jkoch09ultra
With it running select GET map. I should display the currently loaded map. You can go to to OPEN map and see all them maps in your laptop. You can then select one and change it. Then SEND map to the PCIII. Play with it some.
If you have popping on deceleration you can add 20's to the first column at 1500, 2000, 2500, 3000. If it still does it you may have to go up to 30's in the first column(0 throttle position).
Don't forget to SAVE changes you made. You can call the altered map anything you want.
You will hear this a thousand times. Find a certified dynojet tunner and have it dyno tuned. I only paid $150 for mine. I would not take it to Harley to be tuned. They cost way to much and will keep it for days.
Jeff
kryingame
May 19, 2016 10:19 AM
epd612
Nov 21, 2010 12:21 AM
JCK
Jul 13, 2009 07:32 PM
bullin
Sep 11, 2007 12:32 AM
ORCUTTHD
Mar 29, 2007 09:16 AM
