ARC audio question
Old Jan 19, 2010 | 09:18 PM
bikerbehaviorist's Avatar
bikerbehaviorist
+1 on firecap
I drive 4 - 4 ohm speakers with the 125.2 and the sound is awesome! There is a formula that shows how doing this actually makes the system have 2 ohms per side. If you would like I can try and find the link to the article that talks about this. If you are using the original harley 2 ohm speakers I think that is fine. My amp has run just fine and has not overheated even in 90-100 degree days in N. Calif. If I am not giving correct info please correct me.
Old Jan 19, 2010 | 09:31 PM
Harleypingman's Avatar
Harleypingman
If you go to Arc's website and download the pdf installation instructions for the 125.2 mini, there are pictures showing the wiring of 4 ohm speakers for 2 ohm impedance "seen" by the amp as described by bikebehaviorist.
Old Jan 19, 2010 | 09:45 PM
cap5369's Avatar
cap5369
+1 on the ARC amp, I also have the 6.5 arc speakers. Very easy install and all I did was take my CB and mount it under the stereo perfict fit and put the amp on top. I agree Call Wayne he is awsome to work with and will even walk you thru tunning it. Just the upgraded speakers where nice but night and day difference when you add the amp.
Old Jan 19, 2010 | 09:53 PM
Terminator69's Avatar
Terminator69
Take a look at the wetsounds amp, It is pretty much the same as the arc but it has more water resistance and cheaper. I have the wetsounds amp and a pr of 6.5 Memphis Audio speakers and it Kicks ***, My gal says she can hear it on her bike next to me with her helmet on. Pretty easy install also. http://www.throttleupindustries.com/hdforum.html
Bugsy
Audio Systems
20
Jul 22, 2018 08:07 PM
mjonesjr84
Audio Systems
25
Dec 4, 2016 12:23 PM
Ganooch
Audio Systems
18
Jan 21, 2015 10:34 AM
davessworks
2014-2024 Touring Models
19
Aug 2, 2014 06:22 AM
Sincecrazy
Mar 13, 2010 06:34 AM
