ATF in Primary???
Old Jan 23, 2010 | 07:22 PM
BLKBAGGER's Avatar
BLKBAGGER
Dexron II for the last 30,000 in two different bikes. IMHO it works great and it's cheap. The syn stuff doesn't grab quite so good I noticed.
Old Jan 23, 2010 | 08:15 PM
themensh's Avatar
themensh
Anyone running Marvelous Mystery oil or WD-40?
Old Jan 23, 2010 | 08:16 PM
Moonrider's Avatar
Moonrider
Originally Posted by Pacodelahoya
I run B and M Trick Shift. 8000 miles and no probs.
Ditto. Change every 8k (every other oil change)
Old Jan 23, 2010 | 08:18 PM
lrays280z's Avatar
lrays280z
Type F ATF for last 5k. Seems fine.
Old Jan 23, 2010 | 08:26 PM
boogiewithtuck's Avatar
boogiewithtuck
Mobil 1 Syn ATF - Change every 10,000 miles - 20K so far without any issues - I have no problems with grabbing, slippage, etc.... I run Mob 1 gear oil in the trans and Mob 1 oil in the motor - changed every 5K.
Old Jan 24, 2010 | 11:32 AM
dawg's Avatar
dawg
Dexron III non synthetic
Old Jan 24, 2010 | 12:17 PM
dog155's Avatar
dog155
Talk to any clutch people they will tell you to use ATF in primary drives.These fluids are designed to work with the clutch plates.Motor oils are not.
Old Jan 24, 2010 | 12:37 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Vavoline DexronIII/Mercon in my primary. Perfect clutch actuation and hookup!
Old Jan 24, 2010 | 12:51 PM
GreenRK's Avatar
GreenRK
B&M trick shift here also.
Old Jan 24, 2010 | 01:02 PM
FLYING's Avatar
FLYING
I started running ATF in primaries over 20 years ago with wet or dry plates and have had no problems.The biggest reason to run that was the cost of ATF vs. Primary lube.
Road Star
Oil Archive (no new posts)
Sep 18, 2016 07:02 PM
extip123
Oct 2, 2014 01:11 AM
Hi-perf old poop
May 5, 2014 01:37 PM
NECaveman
Sep 30, 2012 11:11 PM
Frankster69
Aug 30, 2008 07:38 AM
