Hand Grips?
Old Jan 27, 2010 | 12:08 AM
Dallastx's Avatar
Dallastx
Default Hand Grips?
So How do I do it on my 09 Ultra?
Old Jan 27, 2010 | 12:10 AM
Dallastx's Avatar
Dallastx
Replacing that is...
Old Jan 27, 2010 | 12:14 AM
BlackFLHR's Avatar
BlackFLHR
Super easy. You just need to split the switch housings in half by removing the 2 screws in the switch housing and by loosening the brake and clutch perches. Open the switch housings and the grips slide off. If you have the OEM grips on, then you'll probably need to use a razor blade to split the left side, as it is glued on.
When getting new grips, be sure to get ones made for the 08+ touring models.
Old Jan 27, 2010 | 12:38 AM
PistonPuller's Avatar
PistonPuller
http://www.kuryakyn.com/index.cfm/go...er/VideoID/28/
Old Jan 27, 2010 | 06:57 AM
3dynaP's Avatar
3dynaP
Just be careful of pinching wires...don't ask how I know.
Old Jan 27, 2010 | 07:35 AM
bman7163's Avatar
bman7163
Go to motor accessories section at HD's website. Put in the year and model of your bike. Then select hand controls and find a set of normal unheated grips. Once you have selected a particular grip you are able to download the the instruction sheet for installing.
This should give you everything you need to replace your grips.
Old Jan 27, 2010 | 08:31 AM
ftanner's Avatar
ftanner
The grips also come with instructions. I did this just this last Monday.
Old Feb 9, 2010 | 01:23 PM
shortride's Avatar
shortride
I found it. But I didn't see any installation instructions.
Old Feb 9, 2010 | 04:39 PM
Scubamike's Avatar
Scubamike
Heres the links from HD's web site for there instructions on the install.
http://www.harley-davidson.com/en_US...ts/-J04258.pdf
Super easy just take you time and do not pinch the wires. I installed Avon grips on my 09 SG and love them.
Old Feb 9, 2010 | 05:35 PM
DPete's Avatar
DPete
If ya get em lined up right the first time you won't have to do it twice like I did Had the right grip 1 tooth off and didn't see it til I rode it
