Hand Grips?
Old Feb 9, 2010 | 05:37 PM
shortride's Avatar
shortride
Originally Posted by Scubamike
Heres the links from HD's web site for there instructions on the install.
http://www.harley-davidson.com/en_US...ts/-J04258.pdf
Super easy just take you time and do not pinch the wires. I installed Avon grips on my 09 SG and love them.
Thanks, I appreciate that.
Old Feb 9, 2010 | 06:14 PM
troop's Avatar
troop
Don't forget to squeeze the brake lever and put some type of shim (cardboard) between to keep it open. Don't want to break your brake switch ...
Old Feb 9, 2010 | 06:26 PM
deucer03's Avatar
deucer03
A good trick for removal is to take a small air nozzle and use a compressor to work the grip off.This prevents using a razor knife and gouging your bars.
Old Feb 9, 2010 | 06:34 PM
harley-jones's Avatar
harley-jones
Make sure you do the throttle side first. It's position is set.
Then do the clutch side and match it to the pattern on the throttle side grip. I hope this makes sense.
You will most likely glue the clutch side grip, so do it last.
Conehead
Aug 19, 2010 04:23 AM
SBW Cycles
Sep 8, 2009 07:30 AM
maddoggreene
Jan 31, 2008 06:53 PM
diablo666
May 23, 2007 11:48 PM
Sreynold1
Oct 21, 2005 12:20 PM
