removing stripped primary drain plug-UPDATE!
Old Jul 22, 2006 | 06:53 PM
dawg's Avatar
dawg
Default removing stripped primary drain plug-UPDATE!
OK so I am trying to change my primary fluid. I had the right allen head wrench and there is no way that the dealer torqued that bolt to the proper specs. It wasn't moving and it is starting to get stripped. I know I will be getting a new plug now, but any ideas on how to remove this one?
Old Jul 22, 2006 | 07:12 PM
bountyhunter's Avatar
bountyhunter
Default RE: removing stripped primary drain plug
No way the head should strip if YOU use the CORRECT tool...now ya need an EXTRACTOR![:@]
Old Jul 22, 2006 | 07:22 PM
ROADTRAIN's Avatar
ROADTRAIN
How can that be, you can't overthighten that plug it will just keep screwing into the primery as it is a tapered thread, unless it's the new type with a shoulder and O ring but these too are only tightened up to the O ring.
What you can try is find a torx bit that you can lightly tap into the plug and then screw it out. Other than that drill it out but you will need to remove the cover.
Good luck.
lp's Avatar
lp
If you still have some bite take a piece of ice and try to cool it down and then go for it. If that don't work, go to an auto parts store and get an "easy out". You'll need to drill a little hole, insert the easy out and twist till it comes out. It's easier than it sounds.
good luck
lp
Old Jul 22, 2006 | 07:48 PM
dawg's Avatar
dawg
I used a 3/16 allen wrench. Is that the correct size. I have screw extractors so I can try that.
Old Jul 22, 2006 | 09:21 PM
otterbob's Avatar
otterbob
Since its already stripped, maybe a metric allen wrench would fit tight enough to get it out? Just a suggestion.
Old Jul 23, 2006 | 04:18 PM
dawg's Avatar
dawg
Default RE: removing stripped primary drain plug-UPDATE!
Well, thanks to some suggestions here I was able to remove the allen plug by hammering (lightly) in a torx 30 bit and it grabbed and backed the plug right out. I have now changed the primary fluid and used HD Formula+ in the primary. How do others put the fluid in? I used a funnel connected to a tube and put the tube in through the top of the opening. Now I also have my nice new derby cover installed.
Old Jul 23, 2006 | 05:24 PM
TKanaley's Avatar
TKanaley
ORIGINAL: dawg
http://www.corbin.com/accessories/ezpour2.shtml
Old Jul 23, 2006 | 05:40 PM
dawg's Avatar
dawg
Wow, that's neat. Do you have one, or just posted the link? A hose and funnel is still cheaper, but that is neat.
Old Jul 23, 2006 | 05:56 PM
JBBOOKS's Avatar
JBBOOKS
On my 05 RKC, the primary drain plug is a torx 30.
I can't get my clutch inspection cover off without removing the passenger foot rest, so I pull off the primary chain inspection cover (T27), and pour the new fluid in through there. It takes a full bottle and I never have had a problem doing it that way with simply a long funnel.
Glad you got the drain plug out. Stuff like that is a major PITA.
Memo7070
Sep 20, 2013 07:26 AM
laserman2431
Sep 21, 2012 02:24 PM
Turbo Turtle
Aug 15, 2010 02:57 PM
Chambeaux
General Topics/Tech Tips
May 9, 2010 06:19 PM
kraig205
Apr 30, 2008 04:05 PM
