Security system problem
Old Jan 31, 2010 | 11:02 PM
Harpoonman's Avatar
Harpoonman
The older style fobs, with the button.... you can syncronize the security system to the fob's frequency..... The new system syncronizes the fob to the system frequency, and is not user programable.... this is what I was told, when my dealer failed to activate the security system when I took delivery.
Old Jan 31, 2010 | 11:19 PM
SBFD8's Avatar
SBFD8
Question
I have 2 fobs i changed the battery in one and not the other one they are the automatic type i tried each one and I have not changed the code and i do not know what it is. Guess I should have paid attention when the dealer told me what it was and my memory is not worth a sh-t anymore. I really appreciate all the help. Thanks
Old Jan 31, 2010 | 11:21 PM
SBFD8's Avatar
SBFD8
Anyone know what the factory default might be
Old Jan 31, 2010 | 11:24 PM
Harpoonman's Avatar
Harpoonman
PM sent
Old Feb 1, 2010 | 06:46 PM
SBFD8's Avatar
SBFD8
Old Feb 1, 2010 | 07:18 PM
Harpoonman's Avatar
Harpoonman
Were you able to manualy override your security with the turn signal process??
Old Feb 1, 2010 | 07:34 PM
SBFD8's Avatar
SBFD8
No I tried as you suggested but it would not work I guess I will have to talk to the Dealer tomorrow. I appreciate your help. Thanks Al
Old Feb 1, 2010 | 07:50 PM
Harpoonman's Avatar
Harpoonman
Well, dang it !! There must have been a change in the default. We are comparing apples to oranges, since yours in 07 and mine is 09. I will double check my manual to be sure I told you correctly. I'll get back to ya. I guess it is possible that the security module may be bad. With the intermittent operation you were describing that was my first thought. But I know we need to eliminate the simple things first. Which you started with....
Old Feb 1, 2010 | 09:43 PM
thereal142's Avatar
thereal142
I put new batteries in both my fobs last spring and did not have to reprogram anything.
Old Mar 19, 2010 | 07:45 AM
rockey's Avatar
rockey
6th Gear
Default security system issues
OK, I found that for some reason over the winter my trickle charger did not charge my 07 Street Glide. I went and purchased a battery from battery warehouse due to Harley being on back order for at least a month. However I am now finding that the security system does not want to recognize either of my security fobs. I always kept one fob less than 5 feet from bike and the other in my home. I tried to replace both fob batteries and still not recognizing. I just keep getting the flashing security lights and the iluminated security key in the display. Now if i manually overide the system with my new pin number it will start fine. I also tried to get it to allow me to change the pin number but for some reason will not allow me to utilize the method in the manual. I really dont like entering the security code every time I want to ride. Is there something that I can do or does this need to goto the stealer to have them fix it. I have extended warranty until 2014 so if that is the case no worry but down time. can you help me
