2005electra glide smoking
Old Jan 31, 2010 | 08:03 PM
stephen1767's Avatar
stephen1767
1st Gear
Default 2005electra glide smoking
have a 2005 electra glide standard smokes at start up any ideas whats wrong has 21000 miles just started doing it smells like oil
Old Feb 1, 2010 | 12:07 AM
BLKBAGGER's Avatar
BLKBAGGER
Sounds like a valve seal.
Old Feb 1, 2010 | 05:11 AM
stephen1767
1st Gear
any idea what would cause it to go out
Old Feb 1, 2010 | 07:10 AM
dog155's Avatar
dog155
Valve seal, or drain holes in heads are restricted,guides could be worn.
Old Feb 1, 2010 | 09:23 AM
69z28's Avatar
69z28
Valve stem seals.05 were bad to do this.
Old Feb 1, 2010 | 11:01 AM
RHPAW's Avatar
RHPAW
Smoking is a nasty habit. Put some Nicorette in the gas tank.
Not sure why this is in the BS section, but seriously........
as stated, it is probably guides or seals. Could even be a sticking umbrella valve.
Check plugs to narrow it down to which cylinder it's coming from.
Old Feb 1, 2010 | 11:49 AM
FLYING's Avatar
FLYING
Sounds like valve seals or valve guides.Have you tried a cylinder leak down test?
Old Feb 1, 2010 | 12:18 PM
Da Gumpmeister's Avatar
Da Gumpmeister
If I were a bettin' man, which I aint, I'd put my .02 with the 'majority' here, valve seals.
And I'd also bet, if you pulled the plugs, you'd know which one it was, or if it's both. (Unlikely both)
Depending on the 'customer', can just replace seals.
Or at 21,000, decarbon, maybe even touch up the valves and seats, check guides while had it apart. Also gives you a chance to look inside the 'holes'. BUT, that depends on the 'customer'. Read that, how much can they, or will they, spend.
BUT nothing wrong with just seals, either. Specially if ALL else, is running good.
Trust me, in 'the$e' times, I'm cutting corners, too, BIG TIME.
Old Feb 1, 2010 | 01:04 PM
stro1965's Avatar
stro1965
I agree on the valve seals. There were a bunch of '05's with bad seals. HD was replacing them long after warranty but now, 5 years later? You might be on your own. Good luck!
Old Feb 1, 2010 | 01:27 PM
jdreed520's Avatar
jdreed520
Valve seals......pretty easy fix.......
