A Battery Question
Old Feb 6, 2010 | 03:53 AM
FLHXXHLF's Avatar
FLHXXHLF
Originally Posted by CroK
you are seeing a voltage drop. Amperage is what counts. Have some one check the output of the charging system to see if there is a problem. Unless you know how to use the multimeter and an ammeter also. You said the guy who worked on the bike had a problem charging the battery, was he charging the battery with the engine or a battery charger? I wouldn't rule anything out at this point, and don't blame the mechanic yet. Coincidences do happen...
Not blaming anyone actually. Just trying to get my scoot going without having to take it back to the shop. i'm ready to RIDE !
Old Feb 6, 2010 | 07:21 AM
kyote's Avatar
kyote
Check the battery grounds first.. bad grounds will keep your battery from charging fully...
To check if the stator is putting out enough AC Votage.. Pull off the Regulator to Stator plug..use a meter to check for contituity between either of the 2 pins and the crankcase.....should be zero Ohms.. Resistance should be .o1 - .02 ohms across the stator socket... if not..stator is bad. start the bike...take a reading across the socket...it needs to be at least 32-40 AC Volts at 2000 rpm. if not..stator could be bad..
Old Feb 6, 2010 | 03:14 PM
ZBARK's Avatar
ZBARK
Originally Posted by jimsreddyna
On a Harley, you are running everything off of the battery not the charging system like in a car. On a car, if you disconnect the battery everything will keep on running off of the charging system but on your bike if you disconnect the battery while it is running, it will die and everything will go dead.
Hmmm....did exactly the opposite on my 2001 RK Classic.Battery died,would'nt even take a jump.Took my buddies battery out of his EG and started my bike with it.Then removed his batt. and put the dead one back in my bike as it was running.
spalmer1214
May 22, 2021 03:34 PM
moreira72
May 31, 2019 03:35 AM
Steinimal
Electrical/Lighting/Alarm
May 28, 2017 04:26 PM
WOLFE1584
Mar 11, 2013 05:57 PM
Ten-Ring
Sep 17, 2010 10:22 AM
