09 sg sweeper bar install,wiring cables??
Old Feb 6, 2010 | 11:10 AM
DPete's Avatar
DPete
Originally Posted by dawg
Yes, no green connector
That's the way to go then if you can swing it. Getting that green connector thru the bars with all the other wires is a PIA
Old Feb 6, 2010 | 11:18 AM
eurojeff's Avatar
eurojeff
Yeah dawg been out there 2 times already in 24 hrs trying to keep it managable ,and the stuff is still falling,d**m this is why i left upstate NY! At least it only happens every couple years,i guess NC/SC looking better & better. Anyways plenty to do inside gettin ready for spring, Thank for info Bigdebo
Old Feb 6, 2010 | 11:21 AM
eurojeff's Avatar
eurojeff
Maybe a little tape & lube on harness,like running house wiring through conduit with fish tape?
Old Feb 6, 2010 | 11:24 AM
PistonPuller's Avatar
PistonPuller
Yeah, but fish tape is too stiff. I used a small chain, like a lamp chain. Some use a string with a small nut tied around it. And make a drawing of the wires when you disconnect the molex. You will save loads of time.
Old Feb 7, 2010 | 06:51 AM
eurojeff's Avatar
eurojeff
BennieSG,thats a good idea using lamp chain,more flexible but strong enough to pull the wires. Did you use a blk or braided clutch cable,im thinking for the time im going to install these maybe go braided,any recommendations.
Old Feb 7, 2010 | 10:19 AM
PistonPuller
I went with the braided lines and cable from hdbikeparts.com. The guy was reasonably priced and knew what size I needed by the bars I told him I was using. He also answered a few questions I had along the way. Saved me some time. I would use him again.
Titan56
Feb 3, 2013 10:18 PM
kathygreg
Jul 29, 2010 06:45 AM
Bobshx
Feb 3, 2010 08:02 PM
gmurdock
Feb 22, 2009 06:42 PM
Kato
Sep 3, 2008 12:46 PM
