Late model wheels fitting earlier model bikes
Old Feb 7, 2010 | 04:25 PM
niteglide's Avatar
niteglide
Default Late model wheels fitting earlier model bikes
What was ever decided about wheels with the 25mm axle fitting bikes with 1" axle? I saw where this had come up earlier posts but never read where someone had actually done it. Anybody know?
Old Feb 7, 2010 | 04:43 PM
nedster's Avatar
nedster
HD has wheel fitment kits.
Old Feb 7, 2010 | 04:59 PM
jdreed520's Avatar
jdreed520
I have been told that you can change the bearings in just about any wheel to make it fit a earlier model.
I personally just swapped my from fork down tubs for a 2000+ model and then i can use a 1" axle wheel. As far as the rear you can swap out a 2000 and earlier swing arm with a 2004 or so and get the bigger axle.
Old Feb 7, 2010 | 05:15 PM
SE120RG's Avatar
SE120RG
I recently installed a front wheel from a '10 SG on my '07 RK. The hubs on my 07 were not machined to be centered. By that I mean, the axle spacers were different sizes and needed to be installed on the proper side so that the brake disks would line up with the calipers. The 2010 wheel hub is machined centered. The axle spacers were the same size. I used the axle and spacers from a 2009, and wheel from the '10 and everything worked perfect. Another member posted on the thread I had started about this and said he had bearing failure from swaping out the 25mm bearings for the 1" and using the older axle with the ofset spacers.
Hope this helps.
Old Feb 7, 2010 | 05:34 PM
1sweetglide08's Avatar
1sweetglide08
I did a 2010 wheel on a 2008....it was a direct bolt on.
Old Feb 8, 2010 | 08:05 AM
dog155's Avatar
dog155
I believe it is the axle size you want to look into.Up to a certain year they were 3/4" later models are 1"
Old Feb 8, 2010 | 12:05 PM
GzrGlide's Avatar
GzrGlide
My '01 had the 3/4" rear axle
In '02 they went to a 1" rear axle and in 2008 they went to the 25mm axle.
I was still able to put 2007 SG wheels on my '02 Classic.
You can get the bearings replaced to fit whatever axle you happen to have.
abez
Wheels/Tires
Oct 31, 2016 03:15 PM
johnod
EVO
20
Feb 19, 2015 03:32 PM
jakespade
Jun 12, 2013 06:47 PM
DrewCfromSC
EVO
Mar 30, 2011 05:56 PM
blackness
Jan 10, 2008 09:55 PM
