Brass Fairing Inserts (pics)
Old Feb 18, 2010 | 06:53 PM
Overdoo's Avatar
Overdoo
Default Fairing thread repair
If someone doesn't have access to these replacement parts because their local dealer doesn't have them and there in desperate need, heli-coils work equally as well. 1/4-20 kits are available at most auto parts stores.
Old Feb 18, 2010 | 06:56 PM
Hog Yild's Avatar
Hog Yild
I just epoxied one of mine back in, it's held for the last two years.
Old Feb 18, 2010 | 07:34 PM
Moog Player's Avatar
Moog Player
Epoxy didn't work for me. I heated the plastic with a heat gun until it was very slightly softened and pressed the old insert back in. Then I out a small hose clamp on the fairing to squeeze it down. Has been working so far. That fitting is available from McMaster or most good industrial hardware stores.
Old Feb 18, 2010 | 08:02 PM
jkglide's Avatar
jkglide
Subscribed - thanks I needed this fix!
Old Feb 18, 2010 | 08:13 PM
harley-jones's Avatar
harley-jones
Originally Posted by Harleypingman
HJ, great timing; had to replace one today for the first time.
A tech at the dealership told me if the slotted end is used with a screwdriver, it almost always happens that some of the threads are lost due to the force exerted by the screwdriver blade causing the top edge to separate.
Your method is actually the reverse of HD's intended installation; and works better IMO; at least it did for me.
Thanks.
Carl
I talked to Dawg in a P.M. and he said that defenitly the slot goes into the plastic first. I went with Dawgs advise and it worked great!
Glad it worked out for you!
Old Feb 18, 2010 | 08:28 PM
YtseJam's Avatar
YtseJam
You guys are making me feel better, thought I was the only one who had one stripped out!
Old Feb 18, 2010 | 09:13 PM
davessworks's Avatar
davessworks
subscribed!
Old Feb 18, 2010 | 09:52 PM
Potato_Potato's Avatar
Potato_Potato
This is one area that I don't use a torque wrench. I prefer instead to use a light weight straight driver and tighten by feel in a pattern then go for a ride and retighten as needed.
Old Feb 18, 2010 | 10:48 PM
tri cycle's Avatar
tri cycle
Thanks for taking the time to post in detail. I used a C-clamp and carefully pressed mine back in and have reverted to tighten by feel approach..but I know it's only a matter of time....
Old Feb 18, 2010 | 10:54 PM
dirtdobber's Avatar
dirtdobber
Yep, that's what I did
