I have a similar problem on my father-in laws 05' FLHT. We put a 21" wheel on the front and can't get it to spin over. My problem though is when the axle nut is tightened. The wheel spins free until we tighten up the axle nut. I think we need to check out spacers but something to check I guess?
The rotors are one piece hogpros. the pistons were working fine before the install. maybe dirt got in. BUt my question is.... why should you have to shim the calipers? Seems like a bandaid for a different problem
If neither the rotor or the caliper floats you need to center the rotor in the space between the brake pads. You do that by shimming the calipers or the rotors. Disc brakes will have a small amount of drag since only the seals retract the pads, but the drag should be slight unless your caliper or rotor is positioned wrong.
If the outer pad is dragging, shim the caliper out from the mount. If the inner pad is dragging, shim the rotor out from the hub. If you run with a lot of drag the resulting heat will warp the rotors.
ok- measured the thickness of the rotors=same. so the calipers have to be shimmed. Now my question is, do they have to be shimmed b/c the new hub size is different and if so is the new hub size different b/c of lak of quality ??
Not necessarily lack of quality, just different size. Are the new rotors setting wider or narrower than the stock set up?
Dont the calipers on an 07 glide bolt to inside of the forks? I know my 08 RK do. Shimming the rotor or the caliper accomplishes the same thing/direction.
My bad! That's what I get for goin' with an old memory! You're right, they bolt inside the mounts, so you would just reverse the shimming depending on which side is rubbing.
Hopefully he is off center with the inside pad, cause he cant shim the rotor in or the caliper out. Thats why cmtbasser ended up milling some material off his caliper.
One thing for sure to check is the brake fluid level, if its too full, those pistons wont allow the pads to hang on the rotors like they should.
Theres a few things to check out, as in cleaning the pistons and checking for proper/even function, pull the pad pins to make sure they have a little anti-sieze so the pads move smoothly and checking the rotors for runout. Just cause their new doesnt mean one could not be out of spec.
spec.
