21" front question
Old Feb 20, 2010 | 08:33 AM
xglide06's Avatar
xglide06
Default 21" front question
For u guys with 21's:
Trying to figure out everything I need for 21" front wheel and had some questions. I want to go to a left side only rotor. How does stopping power compare? Do I need to got to a 6 piston caliper, 13 inch rotor combo? Like the 360 brake, but heard it has too many issue, any opinions on that? Does stock fender need changed?
Thanks
Old Feb 20, 2010 | 09:27 AM
Landon's Avatar
Landon
Check out PM. They have choices that both work and look great. 360 is fighting a bad image problem as well as structural issues. Dont be their guinea pig.
Old Feb 20, 2010 | 09:36 AM
07donkey's Avatar
07donkey
i have a 21 on a streetglide with a 360 brake and no problems i've had it for two year riding to myrtle beach from ohio every year. they have to be installed correctly. as for the fender i did not change mine. here is my set up, 21" wheel, 120/70r21 and a one 6" 360 brake and it stop safely hope this helps
Old Feb 20, 2010 | 10:16 AM
1ADAM12's Avatar
1ADAM12
u should get a 13 rotor with a six piston caliper im not sure of the 360 brake,good luck
Old Feb 20, 2010 | 11:37 AM
FFeric's Avatar
FFeric
Can you use a smaller rotor when using single sided brake?
dloecker
Mar 4, 2016 01:51 PM
Mach1crazy
Nov 6, 2014 09:03 PM
FFeric
May 4, 2014 06:42 PM
bcmwake
Mar 11, 2010 09:03 PM
catfish24
Wheels/Tires
Oct 12, 2009 04:15 PM
