Axle Nut Torque Adapter
Old Feb 22, 2010 | 05:14 PM
big_e78's Avatar
big_e78
Default Axle Nut Torque Adapter
I thought I was buying the axle torque nut adapter HD-47925 but I accidentally ordered a simple axle wrench HD-94695-08. Physics is definitely not my thing. Will I be able to torque to specs (95-105 ft lbs) by hand? Any other ideas?
Old Feb 22, 2010 | 05:17 PM
gman's Avatar
gman
my UC tool kit had a 36mm wrench with a 1/2" cutout for a torque wrench. I use this set-up to do mine.
HDV-GLIDE's Avatar
HDV-GLIDE
Get a 1/2 torque wrench and you should have no problem...Harbor Freight has them cheap!!!
Old Feb 22, 2010 | 05:21 PM
big_e78's Avatar
big_e78
I have a torque wrench but this axle wrench doesn't have a 3/8 or 1/2" hole for the torque wrench.
Old Feb 22, 2010 | 05:49 PM
hojones's Avatar
hojones
I bought my adapter from Pit Posse. It wasn't very expensive.
Old Feb 22, 2010 | 05:56 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Remove either the top or bottom shock bolts and you can jack the bike up or down to clear your pipes and then just use the torque wrench and the appropriate size socket to torque the axle nut....A little bit of work but at least you don't need to buy another wrench...
Old Feb 22, 2010 | 06:33 PM
harley-jones's Avatar
harley-jones
The torque wrench should be 90degrees to the torque adaptor to get an accurate reading.
djdiver157
Wheels/Tires
Feb 27, 2026 08:56 PM
djdiver157
Wheels/Tires
May 30, 2017 03:42 PM
BuddyK
Wheels/Tires
Feb 2, 2015 04:14 PM
LockNut
Apr 18, 2007 12:22 PM
Grendel UK
Oct 31, 2006 11:39 AM
