Best $1.39 spent yet....lose the Torx that hold batwing from inside.
Old Feb 23, 2010 | 06:40 PM
ashmarc's Avatar
ashmarc
Default Best $1.39 spent yet....lose the Torx that hold batwing from inside.
I hate Torx bolts!! The inventor should be tarred & feathered.
The two that go under near the forks.........I'm constantly dropping them when trying to re-install.
Lowe's.......(4) 1/4-20 X 3/4" socket head cap screws (black). The stockers are 5/8" but these work fine.
They stay on the allen head wrench or allen head screwdriver when you're putting them back in place.
Just sayin'.
Old Feb 23, 2010 | 06:56 PM
Primo's Avatar
Primo
Too simple for the rest of us to think of.
THANKS!
Old Feb 23, 2010 | 06:59 PM
twodollarbill's Avatar
twodollarbill
You'll be ok if you don't have an HD tech work on your scoot.....they hate it when the tools in their hands don't work.
Old Feb 23, 2010 | 07:26 PM
makstv5's Avatar
makstv5
Default Torx bolts
Just sayin'.
Are you sure that you are using the right Torx wrench? Generally they work and stay on the wrench fine unless you are trying to use a T25 where a T27 is the size. Or should i say using one size under what the bolt head size is.
Old Feb 23, 2010 | 07:31 PM
bwana1's Avatar
bwana1
Good point, T-25 vs T-27. The T-27 is the size that never comes in a regular set. I have a 10" screwdriver style T-27, and it is probably my most used tool.
Bwana
Old Feb 23, 2010 | 07:39 PM
ashmarc's Avatar
ashmarc
This would be excellent advice if I was a f'in moron, but since I'm not........well.......thanks for the tip anyways.
Old Feb 23, 2010 | 07:40 PM
vbx07's Avatar
vbx07
Thumbs up
That is a fine alternative. Here's another. Two 1/4 20 stud's 1 in. long , and two butterfly wing nut's. Simply screw stud's into the lower fairing, line up the bottom hole's then screw nut's on! Done!
HDV-GLIDE's Avatar
HDV-GLIDE
Did the same thing several months back....Easier then the torx screws.....
Old Feb 23, 2010 | 07:42 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Since the hole area is recessed, your going to mar up the inner fairing tightening them down...
Old Feb 23, 2010 | 07:45 PM
vbx07's Avatar
vbx07
Could go 1 1/2 in. on the stud or at least till it bottom's out, and leave's enough thread to screw on the wing nut's.
