rev tech dfo
Old Jul 28, 2006 | 12:52 PM
jd_underdog's Avatar
jd_underdog
Default rev tech dfo
could someone please tell me what this is and what id does? is it like a power comander? i have a pcIII on my bike put does the dfo work with it or replace it?
Old Jul 28, 2006 | 02:23 PM
ricoman's Avatar
ricoman
Default RE: rev tech dfo
The DFO (or TFI) is a different method of controlling the fuel flow to your engine. Would not work correctly with a PCIII. Does not replace it either. A DFO/TFI is an alternative method of fuel control. The PCIII gives more positive and precise tuning thru mapping etc. A DFO/TFI is a plug-in module which has 4 pots that govern fuel flow a different rpm's and these can be adjusted to get the fuel flow that works best. They are well suited to be used on engines with minimal mods (pipes, filter, stage 1) where the PCIII offers more precise fuel management and does well on that type as well as engines with more extensive mods (95' kit, cams, head work, etc.).
There is a very good explanation of the differences in the tech post section which also includes an explanation of the SERT.
Old Jul 28, 2006 | 02:35 PM
King Rider's Avatar
King Rider
I have the rev tech TFI unit on my bike and it works pretty good with the minimal mods I have. It took a little to get them adjusted. Had a little trouble with pop and such but when added the true duals, all of the decel pop went away and have gained some real nice power now.
It works for me but I think it depends on what performance you are looking for in your bike.
John....
Old Jul 28, 2006 | 02:48 PM
Neckball's Avatar
Neckball
I'm running the TFI, working good for me with the changes I've made (see sig. below). Very simple install, simple to tune. It's hard to stay off the throttle now.
cdn.biker
Jun 15, 2011 08:52 PM
ironhead3fan
Jan 14, 2008 08:23 PM
Zipper
Nov 18, 2007 09:30 AM
thumper05
Aug 25, 2007 04:52 AM
imboden
Apr 8, 2007 08:01 PM
