Will I need it remapped?
Old Feb 25, 2010 | 11:26 AM
jnd42697's Avatar
jnd42697
Default Will I need it remapped?
I have a 2006 RK Custom. It is stock except for a Power Commander and Rhinehart True Duals. My question is if I remove the mufflers that are on it and put Samson straight pipe fish tails on it will I have to get it remapped?
Thanks
Old Feb 25, 2010 | 09:17 PM
shagnasty's Avatar
shagnasty
check the power commander website. They may have a map for your combo you can download and try.
Old Feb 25, 2010 | 10:41 PM
user 8373900's Avatar
user 8373900
If you don't also have an aftermarket air filter you don't even need the power commander....
Mark
Old Feb 26, 2010 | 12:59 AM
NoCoLoco's Avatar
NoCoLoco
Get a hi-flow intake and remap.
Old Feb 26, 2010 | 08:00 AM
Heathen's Avatar
Heathen
If you already have the Power Commander, why not dial this change in.
Old Feb 26, 2010 | 08:08 AM
VETERAN75's Avatar
VETERAN75
If you opened up the exhaust you should have opened up the intake also. They work together. You can essentially get more out but you aren't really taking any more in so you don't need any more out. You basically only changed the sound. So you may want to check the PC website for a map, but the current map will probably be fine just not the most capable. I and most everyone else would advise adding a high flow intake. Then with a good map you should notice a difference in performance. BTW I am right below you in Lancaster. Good riding.
Old Feb 26, 2010 | 08:15 AM
MLWilson's Avatar
MLWilson
Yes, but first open up the intake and feel the power of your changes after it's remapped.
lostrider06
May 6, 2015 05:45 AM
ric306
Jul 5, 2012 11:44 AM
Mpc1177
Jul 1, 2012 08:59 PM
shakak
Sep 28, 2010 06:52 PM
skos
Apr 22, 2005 01:06 AM
