No More Clunk
Old Mar 7, 2010 | 12:21 PM
  #171
hog-doc's Avatar
hog-doc
Originally Posted by Faast Ed
Not sure if it's okay to talk tech or not, but I just thought of another thing that can cause stiff shifting and hard to find neautral.
Over filling the primary can cause this.
If it calls for 26 oz - use 26 oz (some softails), don't just throw a quart in there because it is easier.
Over filling is not good.
You are absolutely correct about the over filling, BUT you dont just dump in a measured amount of fliud either.
With the bike upright, meaning verticle and level, meaning horizontal you fill the primary to the BOTTOM edge of the clutch SPRING!
Old Mar 7, 2010 | 12:39 PM
  #172
Faast Ed's Avatar
Faast Ed
Excellent point. Needs to be confrirmed using the method you stated.
But the "called for" amount often gets it close to there. Not always, and should be confirmed.
horizontal
Worth mentioning again. Sometimes your jack (if not centered) will have your front wheel higher than the rear. I almost got fooled by that recently.
Old Mar 7, 2010 | 04:42 PM
  #173
scoteh's Avatar
scoteh
https://www.hdforums.com/forum/prima...ine-clutch-54/
The perfect place for you.
Old Mar 7, 2010 | 04:43 PM
  #174
rbabos's Avatar
rbabos
WTF. You guys best buds now?
Ron
Old Mar 7, 2010 | 05:25 PM
  #175
ranger56528's Avatar
ranger56528
lot of pissin going on about a clunk that if it was a bad thing Harley would of fixed from the git go,all i say is if ya dont like the clunk buy a metric for crip sake.hel nxt it will be how to get ried of the rocker noise on a shovel.......Start the bike in gear if ya dont like the clunk(for non kickers of course)........
Old Mar 7, 2010 | 05:34 PM
  #176
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
Klunk is good. I like to hear "Klunk".....Now if you hear "klunk-klunk"....you've got problems!!!
Old Mar 7, 2010 | 06:27 PM
  #177
scoteh's Avatar
scoteh
Ron
Bwaaahaaaaahaaaaa!!!!!!
Old Mar 7, 2010 | 07:43 PM
  #178
Faast Ed's Avatar
Faast Ed
Yeah, Harley fixes everything from the git go,...... (like when they had that crank run-out issue).
Old Mar 7, 2010 | 07:54 PM
  #179
Faast Ed's Avatar
Faast Ed
Ron
Ain't u ever seen a love/hate relationship before?
We just be passin' the winter duldrums with some messageboard debate action.
No hard feelin's from me.
Thanks for the link, BTW.
Old Mar 7, 2010 | 07:57 PM
  #180
hog-doc's Avatar
hog-doc
Well lets see, oh yeah thats right they did fix it as soon as they verified there WAS a problem. I have one of those bikes .059" runout checked friday afternoon had a new motor monday morning.
As soon as they figured out what WAS causing the problem it was taken care of.
When there is NO PRBLEM they dont fix it, kinda like the trans clunk that IS NOT a problem and the stock comp that IS NOT a problem or the 5th gear whine that IS NOT a problem. NONE of these has ever failed, just caused whining owners!
