Oil Leak?
Old Feb 27, 2010 | 12:37 PM
dwhite74's Avatar
dwhite74
Default Oil Leak?
MY 2008 ultra has started leaking oil at the grommet that has the wires for the alternator (front primary).........whats the correct fix? can it be repaired from the outside or does one have to go inside to be fixed............
Old Feb 27, 2010 | 01:16 PM
Olde Skool's Avatar
Olde Skool
Yup, inside. You have to replace the stator as the grommet is molded to the wire. Do you have a shop manual? It will explain what is necessary to replace it. Mine was replaced under extended warranty at approx 40,000 miles a couple of months ago...
Old Feb 27, 2010 | 03:30 PM
big cahuna's Avatar
big cahuna
If it's not covered under warranty, go to the dealer and price all the parts you'll need. The decide if smearing some black gasket sealer around the plug, is something you can live with.,,
18BKLR
Aug 18, 2010 08:33 PM
dgretz
Dec 5, 2008 06:21 PM
20monster07
Nov 26, 2008 09:06 PM
trackadaptor
Mar 17, 2008 02:04 PM
bulldogmoe7
Jun 4, 2007 07:35 PM
