Problem with installing my Fairing WIDE OPEN CUSTOM
I have a problem with installing my Fairing CUSTOM WIDE OPEN on my Road King Classic 08.
Not within the rails of the black rubber washers. I have to force to enter. And when you come is not symmetrical and distorted.
It fits well. It fits the first and the screen.
Has anyone had this problem?. THANKS.
Not write well in English. FORGIVENESS.
THE OFFICIAL WEBSITE THAT MAKES CUSTOM WIDE OPEN.
THE LIGHTS OF FURNITURE AND overtook him:
"FLHR (Road King) Note: FLHRS (Road King Custom) models require the factory quick detach windshield mounting kit, and relocation of the running lights to the front hole.
* This is the ONLY model that has a choice of brackets: Stand up for added wind protection or laid back".
__________________________________________________ _________________________
Si alguién habla espańol y me puede contestar...
Hola amigos...
Tengo un problema con la instalación de mi Fairing de WIDE OPEN CUSTOM en mi Road King Classic 08.
No entra en los railes de las arandelas negras de caucho. tengo que hacer fuerza para que entre. Y cuando entra no es simétrico y se deforma.
No encaja bien. No encaja a la primera como la pantalla.
żAlguien ha tenido este mismo problema?. GRACIAS.
No se escribir bien en inglés. PERDON.
EN LA WEB OFICIAL DE WIDE OPEN CUSTOM PONE ESTO.
LO DE LOS FAROS AUXILIARES YA LO HE ADELANTADO:
*This is the ONLY model that has a choice of brackets: Stand up for added wind protection or laid back".
You may need to take one or both brackets off the fairing and (remove, sand off, smooth, carve, shape, file) some faring material to make the brackets parallel with each other ( | | ). When they are parallel, use spacers (washers) to space them out to the exact same width as the motorcycle mount spacing. Does this make sense? This would be a normal thing to do for a "custom" part.
An Aftermarket Fairing is not as easy as it sounds. Who sells it easy, but it is not so simple.
It installs as easily as the screen. It was a surprise to me such difficulty.
If Wide Open work with me and I solved the problem speak well of them. Meanwhile I have only negative words.
Desde que nosotros no podemos ver su bicicleta es difícil de ayudar, arrepentido.
or;
Puesto que nosotros can' t considera su bici que es duro ayudar, apesadumbrado.
----------- Original Text ----------------
Since we can't see your bike it is hard to help, sorry.
The problem I have is that does not fit the fairing on the four points of the bike. It fits well in the four rubber washers home where the screen is hosted in the Road King.
The problem is when adjustment as glasses do not fit on the head and ears.
EXAMPLE:
When a crystal glasses is higher than the other ...
I think now em explain better. I put a picture in the first post up there.
I've tried everything and do not get to the solution ...
Can I send you the fairing and I change it by another under warranty?.
THANKS.
