You should be fine if all you've changed is from V&H basic slipon's to Rush slipon's. A 2 inch baffle in the rush muffler should be about the same as V&H basic. If the Rush's are 1.75's you may be a little richer. I see no problem. Get out and ride!
As mentioned above, the software supplied on cd will not load on a Vista pc but you can download from the Dynojet site. I had the same issue.
The cd will work on a vista laptop. It will not install by itself when you insert the disk, you just have to click on the cd icon in my computer and the files on the cd will show. I clicked on the run install file and it worked.
So how can I get a map from fuel moto to make this PCV work on an 08 touring bike? Basic Vance & Hines slip ons, Screaming eagle AC, and stock computer?
Hello, please check your email as I have sent you the map for the V&H slip ons and Stage 1 air cleaner for the 08 Touring in the response to the email you sent me this morning. It was sent as an attachement in my email. Please note that for all Fuel Moto map requests users can use the map request page at www.fuelmotousa.com/mapsupport.htm We update maps several times thru out the work day so it should be less than 24 hours (not including weekends) If anyone is in a jam and needs a map immediately and has used the form you are welcome to call us and we can help out. Thank you all for your continued support.
i had the same problem as the OP and had to go to the website to download the software. I plugged up to the PCV and got the map that came from Jamie at FuelMoto but I can't get it to accept the firmware upgrade, is it necessary to upgrade?
