Help with Wheels
Old Mar 8, 2010 | 12:02 PM
6burgh's Avatar
6burgh
Unhappy Help with Wheels
Trying to find a 21 / 18 setup for my 2007 FLHT w/ABS. I'm being told that no one makes a rotor/ wheel setup for the 2007 ABS. I can get wheels but I've got to disconnect the ABS! Anyone out there find a setup that will work and keep the factory ABS?
Old Mar 8, 2010 | 12:08 PM
Biggzed's Avatar
Biggzed
Just a guess, but your probably throwing them off by the year of your bike. HD didn't put ABS on the civilian bikes until 2008. Your police bike probably isn't common enough for whoever your asking.
If the 2007 ABS is the same as the 2008, you don't need to worry about wheel and rotor set-ups, just the wheel bearing. If they're different, you should just be able to swap your wheel bearing, spacers, and rotors over to the new wheel. Won't be as pretty as a matching rotor, but you should be able to keep your ABS.
Might try giving Hogpro a call as well.
Zach
Old Mar 8, 2010 | 12:53 PM
6burgh's Avatar
6burgh
Thanks Zack, I started with Hogpro, ordered on line, they called and refunded my money.
The 08 ABS is different from the 07.
I guess I'm stuck finding a wheel and using my stock rotors?
Old Mar 8, 2010 | 02:44 PM
Biggzed's Avatar
Biggzed
That's what I was afraid of. Yours has the slots around the inside diameter of the rotor doesn't it.
Sorry about that. You could polish the rotor. They look pretty nice that way.
Zach
HD REBEL
Touring Parts
Feb 15, 2017 06:44 PM
Varooom
2014-2024 Touring Models
Feb 3, 2015 03:56 PM
dufish
Wheels/Tires
Jan 3, 2013 08:55 PM
joelin5386
Wheels/Tires
Mar 12, 2009 01:10 PM
cfoster80
Feb 9, 2009 11:01 PM
