Throttle by wire
Old Mar 11, 2010 | 10:37 PM
SaltyHawg's Avatar
SaltyHawg
I would not want it. I don't trust computers after what's happened with Toyota.
Old Mar 11, 2010 | 10:43 PM
Oldman Harley's Avatar
Oldman Harley
It all just depends on who is doing the programing.
Old Mar 11, 2010 | 10:53 PM
SaltyHawg's Avatar
SaltyHawg
Exactly! and let's hope he didn't have a bad day or that there's a little too much humidity in the air! Be safe!
Old Mar 11, 2010 | 10:55 PM
Rustell's Avatar
Rustell
You have to wonder tho....How much do these two systems have in common..?
Old Mar 12, 2010 | 01:04 AM
roadgliderick's Avatar
roadgliderick
you will like the tbw cleaner look
Old Mar 12, 2010 | 09:25 AM
soundman's Avatar
soundman
Toyota's problem was the actual pedal assembly sticking some, not anything to do with computer or throttle by wire. The fix was to check pedal and install the proper shims to ensure free movement. BTW, Toyota isn't the only one using throttle by wire...most all are using it now.
Old Mar 12, 2010 | 10:23 AM
SaltyHawg's Avatar
SaltyHawg
Did not intend to single Toyota out. Toyota just has no idea what's causing the problem. They thought it was a floor mat. Then something else. However, I have been looking into it and found stories like this all over.
Toyota first installed electronic throttles in 2002 model year Lexus ES and Camry sedans. Total complaints of sudden acceleration for the Lexus and Camry in the 2002-04 model years averaged 132 a year. That's up from an average of 26 annually for the 1999-2001 models, the Times review found.
Now Toyota is looking into a fix that involves an override to apply brakes or something if the trottle by wire system fails. I don't know about you, but on a motorcycle, I wouldn't want my fate decided by a computer system failure and another system trying to apply brakes. just my $0.02.
Old Mar 12, 2010 | 10:27 AM
SaltyHawg's Avatar
SaltyHawg
Here's a good video that discusses how the Toyota system works.
http://www.toyota.com/recall/videos/...lecontrol.html
Old Mar 12, 2010 | 10:30 AM
arealinvestor's Avatar
arealinvestor
I like the cleaner look,but not all tuners are good with the programming of it,if you do a bigger ci build!!!Not to mention HD 58mm TBW being on back order!!!
Old Mar 12, 2010 | 10:31 AM
PistonPuller's Avatar
PistonPuller
The difference with Toyota and Harley is that Harley still has a manual clutch and my non abs has manual brakes. If for some reason my tbw takes off, I can pull my clutch and apply brakes, and come to a stop.
