Sohotbikes wedge
Old Mar 21, 2010 | 10:10 AM
  #31
hog-doc's Avatar
hog-doc
Originally Posted by WVULTRA
Stock unit:
And SOHOT wedge:
And bottom:
If I spent $100.00 on something that looked like it was made in a jr high metal shop class it would have been sent back for a refund immediately, never installed or modified to TRY to make it work.
I understand thier concept, but they have a LOOOOOONG way to go!
Nice job of using consumers to test an obviously not fully developed product though AND getting them to pay for it, excellent marketing!
Old Mar 21, 2010 | 10:43 AM
  #32
Sancho's Avatar
Sancho
What has SOHO had to say about all this? Anyone contacted them?
Old Mar 22, 2010 | 08:28 PM
  #33
WVULTRA's Avatar
WVULTRA
Originally Posted by UltraKla$$ic
Ben, how's that new motor treating you?!?!?! Axtell, eh? Niiiiiiiiiiiiiiice!!!!!
Darren:
Due to wx, still in "break-in" mode.........few hundred miles so far.
Feels/sounds great for now. Looking forward to final break-in while VTuning; then on to the Dyno!
Old Mar 22, 2010 | 08:34 PM
  #34
soos's Avatar
soos
I know that dawg has sent them emails about the unit he had for his '08 and he never heard back from them at all. No response. He has pulled the unit from his primary and has gone back to stock also.
Old Mar 22, 2010 | 09:21 PM
  #35
Wrench53's Avatar
Wrench53
Glad this thread came up! Was looking at buying one of these, after reading all the trouble people have had I'll pass. Being a retired tool & die maker, I was thinking the spring they showed looked kinda weak. Also wondered how well the hydraulic side worked. Any thoughts on modifying the stock one to work like an M6?
Old Mar 22, 2010 | 11:59 PM
  #36
thereal142's Avatar
thereal142
Hayden is about to release an M-6 for the 2007 and up bikes any day now. Their tensioners always worked the best; I have no doubt the new ones will follow suit.
Old Mar 28, 2010 | 12:13 PM
  #37
OnTheFence's Avatar
OnTheFence
Originally Posted by hog-doc
Thats funny the part everybody was raving about turns out to be a piece of crap that has to be modified and remachined to make it work!
After reading all the raving reviews, I bought one as well. Mistake #1 believe testimonials you read on a bike forum. Mistake #2 After having both in my hands side by side, my gut told me that the HD unit on my 08 was better. Mistake #3 Believe teh testimonials you read on a bike forum and install it anyway.
I am not a machinist or hydrologist. But, it doesn't take either to determine that this doesn't work as advertised. There is nothing hydraulic about this thing. The angle of attack on the wedge is not going to push it back.
Lesson learned... Anyone interested in buying my slightly used version?
Old Apr 29, 2010 | 07:41 PM
  #38
krazy3's Avatar
krazy3
has anyone any instance of the OEM making it too tight? I get a howl in my primary when the bike is hot. It's not there when the bike is cold. I pulled off the primary cover tonight and I have about a 1/4" deflection with the bike cold. I'm thinking that is too tight.
Old Apr 29, 2010 | 07:55 PM
  #39
soos's Avatar
soos
On a cold engine you should have between 5/8 and 7/8 inches of deflection and on a hot engine it should be 3/8 to 5/8 inches deflection. I think you are a little snug.
Old Apr 29, 2010 | 07:58 PM
  #40
sifularson's Avatar
sifularson
Have you been getting any metal on the magnet at oil change?
I had a howl in my 07 too. More of a growl actually that came in neutral a went away in gear.
Found that my inner primary bearing was failing.
https://www.hdforums.com/forum/touri...need-help.html
It's not a huge job to get to the bearing although I chose to install a chrome inner primary at the same time. I installed a new tensioner also since the pad on mine was worn.
I also found out that the HD tensioner I bought was a B variation. In other words, HD has made two changes from the original 07 unit. I compared it to the stock tensioner and there were some very subtle differences. For instance, they eliminated the spacers behind it and build them into the tension body. They also beefed up the teeth area.
I have the puller and installer for the inner bearing race. I'll ship it to anyone who needs one. All you have to do is pay shipping back and forth.
