Sohotbikes wedge
Old Apr 29, 2010 | 08:18 PM
  #41
krazy3's Avatar
krazy3
According to this thread, I may have the old style in my '07.
Should I upgrade to the new one?
Old Apr 29, 2010 | 08:29 PM
  #42
sifularson's Avatar
sifularson
I replace mine because I didn't like the amount of wear on the shoe. I've always felt better about spending money to replace worn parts even though the wear was probably normal and not extreme.
When I ordered the 39929-06A, I received a 39929-06B.
Old Apr 30, 2010 | 04:15 PM
  #43
TomWoodgeard's Avatar
TomWoodgeard
Default Number of the spring
Hey Faast Ed; Do you happen to have the # of the spring you purchased at Ace Hardware? It would give me a good starting point. The amount of tension is as important as the length. Thanks.......
Old Apr 30, 2010 | 05:56 PM
  #44
jag1886's Avatar
jag1886
My SOHO is still working just fine. No problems at all.
Old Jan 22, 2011 | 03:01 PM
  #45
CDN. RG's Avatar
CDN. RG
I know this is an older thread but thought I would revive it to get some more feedback on the soho tensioner,I installed one on my 07 rg and it wouldn't tension up at all so I tore it apart again and inspected the unit and what I found was that the check ball was sticking on the seat you could stick a small screw driver in and pop it off the seat but once you put pressure on the ball which is what happens with the hydraulic action it would stick on the seat again,so with the ball sticking on the seat there was no way for the unit to get oil in the cylinder so the hydraulics could work properly.
What I did was take the check ball and spring out,I cut a cue tip in half and put it in a drill and put some metal polish on it and polished up the tapered seat until the ball didn't stick anymore,I then put it back together and it seems to be working fine now but I won't trust it until spring comes and I am able to put some miles on it to see if it will keep working.
Old Mar 31, 2011 | 04:30 PM
  #46
Captain Itch's Avatar
Captain Itch
Sponsor
Any body with an update on this product..? Had one sitting on the shelf for 6 month,s wondering if I should or not..
__________________
www.Captain-Itch.com
Old May 8, 2011 | 09:06 PM
  #47
Bertk's Avatar
Bertk
Hey Larry, it was nice meeting you and the wife last week.
Here's what I posted on another thread just today.
I have had nothing but trouble with the wedge 2 in my 2008 SG. I have tried repairing the one I have per there instruction, but it did not work. The primary is louder than ever. I have requested a replacement or refund. You will find others here that have experienced the same quality control problem as I have.
We will see what they have to say.
Old May 8, 2011 | 10:12 PM
  #48
Captain Itch
Sponsor
Mine is sitting on the shelf..Never did install it.Was very nice to meet the crew,our door is always open to all of you..
k-weaver
Jul 5, 2017 11:51 PM
pug3984
Mar 8, 2011 06:37 AM
adsinclair
Jan 9, 2011 12:23 PM
DanDeuce
26
Jun 13, 2006 10:22 AM
Cohiba_Joe
Oct 14, 2005 01:20 AM
