J&M 7.25 Speaker install HELP!
Old Mar 13, 2010 | 06:05 PM
hdbagr's Avatar
hdbagr
Default J&M 7.25 Speaker install HELP!
Just got my speaker from Dr. V twin. Should the adapter and the speaker grill sit flush against one another?? The wires coming off of the mid and tweeter are epoxied and stick out further in diameter than the adapter ring , not allowing it to set flush!?! if i tighten the way it is, looks like its going to pinch the wires between the grill and adapter.The notches in the grill where the wire goes thru is fine. Anyone else have this problem? Any help is much appreciated.
Old Mar 13, 2010 | 06:09 PM
SICKBAGGER's Avatar
SICKBAGGER
Mine were the same way. But with a little work of moving the wirers where they are glued by pushing them around I was able to get it sit flush.
Old Mar 13, 2010 | 06:43 PM
Trailfndr's Avatar
Trailfndr
I installed them 2 days ago, no issues at all..I also added the light rings...those are awesome..
Old Mar 13, 2010 | 07:16 PM
Roadie09's Avatar
Roadie09
If I remember correctly, one of them has a slot in it. I ran the wires through the slot. It may be between the speaker and adapter.
Old Mar 14, 2010 | 10:32 AM
hdbagr's Avatar
hdbagr
Thanks got them installed had to move the wires and file holes on adapter / grill couldnt get the screw to line up! Did i just get a set thet slipped thru the quality control? 1/2 hour job took little over 2 hours.
rock92
Audio Systems
16
Jul 27, 2019 12:15 AM
meangreen02
Audio Systems
13
Mar 21, 2017 09:57 PM
bladeguy
Audio Systems
Apr 16, 2016 07:28 PM
jackod
Audio Systems
Feb 27, 2015 08:51 PM
jeffreyjames
Jan 3, 2011 10:07 PM
