I tried to put them pretty much where the old ones were since they were fairly centered on the tank. I also used normal visuals to see where they would look good. I spent most of the install time positioning, measuring, re-positioning, re-measuring, etc. until I got them just right
Originally Posted by Chris616
Where did you get the emblems?
I got them at my local Harley dealer. I'm at work right now so I don't have the part numbers handy, but when I get home later, I will grab the box from the garage and post the part numbers up. This is a 2 piece emblem, it has a metal backing plate that sticks on the tank and the outside piece is screwed onto the backing plate.
Where did you buy the emblems? Is it a harley part I can get from the stealer? How much did they set you back? I know I ask a lot of questions, sorry.
Harley dealer, Harley part number, will post them up later. I want to say they were around $50-$75? I'm not sure what I did with the invoice.
Originally Posted by Scorpion07
Very nice - especially on a Road King! They just look right on that bike!
You did a great job positioning them too......
Your next step - flexible pipe for the exhaust. With your nostalgic air filter cover, your on your way to replicating the old FL's of the 60's.
Thanks! That is pretty much the look I'm going for. I need to put the solo seat back on and take some pics out in the sunlight
Originally Posted by Palau
Looks great. The originator of this thread put these on an '04 RK. Does anyone know if these fit the '08 ~ '10 RK/RKC model 6 gallon tanks?
Thanks! Not sure if they will fit the 6 gallon tanks, but the instructions say they fit "fat bob" style tanks, so I would assume they would fit. These emblems have a slight curvature to them so they hug the tank pretty good. If your dealer has any in stock, they may let you check them against your tank.
