rear shift lever vibrating...
Old Mar 20, 2010 | 01:29 AM
coliseum's Avatar
coliseum
Default rear shift lever vibrating...
is that normal? it shakes a lot (the front one doesnt)... a buddy of mine said there must be something wrong :S
Old Mar 20, 2010 | 03:38 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Attached to same shaft = something wrong. Rear must have loose pinch bolt.
Old Mar 20, 2010 | 04:34 AM
BAGGERNATE's Avatar
BAGGERNATE
Keep an eye on it. Never noticed any vibration, but I've lost 2 in the last yr. lever peg and all just gone mid ride. The second go round I checked the pinch bolt before each ride. Then not 5 miles after leaving work, no rear lever and peg. That time I knew I checked it tight, so the bolt couldn't have fallen out. Lever must be cracking before falling off. Switched to billet stye levers, thinking it might be the cast steel OEM levers are prone to breaking. So far so good, but still checking the bolt every time.
NATE
Old Mar 20, 2010 | 10:29 AM
coliseum's Avatar
coliseum
thanks guys...
Old Mar 20, 2010 | 10:45 AM
flight's Avatar
flight
My stealer had to replace mine after it fell off. I was able to find it due to the fact i always shift with the rear shift lever. They ended up replacing the splined shaft and the rear lever under warrenty. Good luck probably just a loose or streched pinch bolt that has now worn down the splined shaft. as long as the bolt is in and the shaft isnt to worn it should not come off.
Good luck,
Steve
Old Mar 20, 2010 | 10:59 AM
Leftcoaster's Avatar
Leftcoaster
The shaft is steel, the lever aluminum. If the lever is allowed to remain loose for a time the aluminum splines will wear allowing the lever to wiggle (as it were) on the shaft. You may be able to cure the looseness by widening the gap in the pinch bolt slot. A hacksaw or cut-off wheel will work for this. If this doesn't do the job replacement is the only remedy. Some use blue loctite (if you re-tighten the bolt you should also re-new the loctite). I use anti-seize and haven't lost a lever since 1995.
apetterez
Apr 20, 2020 04:04 PM
smokewagon
General Topics/Tech Tips
Jun 5, 2015 12:21 PM
apetterez
Feb 14, 2015 07:00 PM
schoolmaster
EVO
19
Aug 20, 2010 02:20 PM
rnl_1200C
Apr 6, 2008 09:55 PM
