What is the best amp
Old Apr 2, 2010 | 07:01 AM
subdoc1's Avatar
subdoc1
Default Amp it up
ARC 125.2 Mini wit HERTZ 165 HCX 6.5", Hogtunes Tweeter Pod off a Alpine 9883 HU mounted in a Hawgwired conversion kit letting you maintain hand controls.
If you have the means .........I highly recommend it.
Just email FIRECAP501 He will take care of ya.
Old Apr 2, 2010 | 07:10 AM
SixSixRider's Avatar
SixSixRider
Running an Arc Audio 125.1 amp with the new J&M 7.25" speaker, but the stock HK head unit. Happy with the set-up, but the head unit leaves a lot to be desired. I'll likely look into some of the ones mentioned in this thread.
Old Apr 2, 2010 | 07:14 AM
timvan's Avatar
timvan
Send your HU to Iron Cross and get the rca outputs. Night and Day difference in sound q
Old Apr 2, 2010 | 12:23 PM
tj316's Avatar
tj316
i'm running the hawg-wired 150w amp and speakers and love it, shop around and you can get deals on them
Old Apr 2, 2010 | 12:48 PM
podrieger's Avatar
podrieger
I put in a pair of J&M 7.25 speakers and have an Elf 2125X amp. Is it possible to slide a power line from the battery, thru the black tubing either side of the frame, to the amp or do I have to remove the battery to do this?
Thanks in advance for any info.
Phil
Old Apr 2, 2010 | 01:19 PM
TRMRC's Avatar
TRMRC
Phil
Ho Phil
I ran the Red wire from the amp underneath the tank in the stock plastic wire housing to the battery and the ground to the ground on the right side of the frame neck. I used the orange wire from the headlight for the "switch" wire. I used 10gauge - I really couldn't hide it anywhere except there.
Old Apr 2, 2010 | 02:53 PM
disturbed07's Avatar
disturbed07
I am running a arc audio 125 amp and really like it,It fits great in the fairing of my sg.
Old Apr 2, 2010 | 04:59 PM
podrieger's Avatar
podrieger
MMCNH
Thanks for the info. I'm going to do the same thing.
Thanks again,
Phil
Old Apr 3, 2010 | 07:05 AM
xtremechopper's Avatar
xtremechopper
Definately get rid of the HK and go with a good aftermarket head unit. The stock unit produces and extreme amount of distortion past half volume and that is why you cannot get a great sound out of them. Even with an amp you will still run into this unless you keep your radio under 1/2. Most people won't realize this because they are not looking for great audio but would rather just volume but for me I want the best I can get in an open air situation. When you pick your head unit get at least 4v preouts and look for a low THD% and you will be very happy. This is just my 2cents worth.
Old Apr 3, 2010 | 08:38 AM
IceHeritage's Avatar
IceHeritage
I use 1 of the Alpine PDX 4.150 digital amps
