Cam Question
Old Mar 21, 2010 | 12:39 PM
buzzpowerz's Avatar
buzzpowerz
5th Gear
Default Cam Question
Does anybody have an opinion on another Cam that is compairable to the S.E. 255 cams.
Old Mar 21, 2010 | 12:51 PM
1931jamesw's Avatar
1931jamesw
Not trying to be an *** to you but I can see you have only made two posts and cam selection is a huge topic here probably right under what oil to use. Of you use the search function in the blue toolbar about a quarter of the way down your the page and type in cam or 255 cam or what cams or anything similar you will pull up more info than you can probably read if you read for the rest of the week even if you don't take a lunch break. that being said, welcome to the forums. There's alot of great people and information here. There's also some a$$holes like me.
Old Mar 21, 2010 | 12:55 PM
BackAgain's Avatar
BackAgain
Come on now..........Let's talk CAMS just one more time...........
Old Mar 21, 2010 | 12:57 PM
VETERAN75's Avatar
VETERAN75
+1 forum search cams, 255 cams, 204 cams, 500 cams, etc.etc.etc. Probably all your questions will be answered and you may even be thoroughly confused. Almost everyone has a favorite.
Old Mar 21, 2010 | 04:11 PM
iclick's Avatar
iclick
If by "comparable" you mean having similar specs and behavior, the new Andrews 48 is as close as it gets.
Old Mar 21, 2010 | 04:31 PM
07RoadHawg's Avatar
07RoadHawg
Or the new Andrews 09H is also a close choice. I'd probably be more likely to go for the 48H for the increased duration and lift as that should fill the cylinders a bit better over the 09H (all things being equal of course...)
kllrvet
Milwaukee Eight (M8)
Jul 2, 2017 07:19 PM
Hillsidecycle.com
Jan 1, 2017 02:49 AM
Disp2030
Exhaust System Topics
May 3, 2012 10:18 AM
klaybus
Jan 8, 2012 10:03 AM
82SturgisFX
May 17, 2008 02:44 PM
