OH $h!T Ignition Lock problem>>HELP!!
Old Mar 22, 2010 | 08:32 PM
Ultra-Snazzy's Avatar
Ultra-Snazzy
6th Gear
Default OH $h!T Ignition Lock problem>>HELP!!
Ok so I seemed to have f'ed up my new scoot. I have a 1998 Electra glide, and I can not get the key in?? the big **** is pointing to the fork lock position forks are not locked...and here is the kicker, the key can not be installed because the barrel key part is between lock and unlock. I can not get the barrel key into the lock! Any ideas??? PLEASE I want to ride!!!!!! Thanks in advance.
Old Mar 22, 2010 | 08:35 PM
ashmarc's Avatar
ashmarc
There'a a great thread in here with an awesome video....search search search.
Old Mar 23, 2010 | 07:51 AM
Ultra-Snazzy
6th Gear
I watched the video (it is great BTW) But the issue I am having is not covered there, I searched for an hour last night and found nothing close. The problem I am having is not the big **** being stuck in the locked position it is that the lock where the key goes in is between the locked and unlocked position so I can not put the key in (no idea how the hell it happened!) try to envision the barrel lock as a clock, unlock is at 11 and lock is at 1 (slot on the key) mine is stuck at 12.
Old Mar 23, 2010 | 08:01 AM
menmia's Avatar
menmia
I would think that you could use the video and other thread to remove the **** and take it to a locksmith. The only other thing I can come up with would sacrifice a key and cut off the key on the key (the part that goes into the slot) so that you can get the barrel in the there and turn the key. The key could be kept as the spare key or you could order new keys to replace it.
Old Mar 23, 2010 | 08:17 AM
gibby122's Avatar
gibby122
sounds like someone may have jacked with it somehow, but if cant even get the key in? short of a locksmith dont know what to tell you. sounds like have more issues as well, if its turned to lock position and its not locked then your tumblers sound like they are off. Did you remove the ignitions switch for anything?
Old Mar 23, 2010 | 08:35 AM
Ultra-Snazzy
6th Gear
I just got the bike last week, I have not taken the switch out...and yes I agree that some one jacked with it. I have a feeling that what happened is that the big **** got turned with the key not being installed...that is the only thing I can think of?
Old Mar 23, 2010 | 08:49 AM
gibby122's Avatar
gibby122
w/out jak'n it up any further can you trun the ignition at all, either way? what happens if you push the release button under the switch and just try to pull up or turn it? anything? may want to play it safe, get and just get a lock smith. the 1st thing would be to be able to get the key in. (I think I just stated the obvious, lol)
Any locksmiths in the house?
Old Mar 23, 2010 | 11:53 AM
Kwayz's Avatar
Kwayz
I have no idea if this will actually work or not, but sounds like you have nothing to lose. Get one of the white Bic ink pens, take the little black cap off the non-writing end, push the (now) open end of the pen down into the lock and see if you can get it to turn (wiggle the big **** a bit while trying to turn the pen). The kind of pen I'm talking about is the kind of soft plastic one, white with black caps. The reason I suggest this is that I've heard that you can use those kinds of pens to "pick" a barrel lock, so it "might" work to get your lock back into the correct position.
Good luck!
P.S. Check this video to see what I mean:
http://www.youtube.com/watch?v=LahDQ2ZQ3e0
Last edited by Kwayz; Mar 23, 2010 at 12:04 PM. Reason: added a link to a video of the pen in action
Old Mar 23, 2010 | 01:05 PM
Ultra-Snazzy
6th Gear
thanks for the replies guys, I am going home tonight armed with a bic pen and a freshly filed down key. After watching the video again I think that the previous owner may have not installed the **** correctly??? anywho I will follow up and let you all know if the pen trick works lol.
Old Mar 23, 2010 | 06:40 PM
rushbass's Avatar
rushbass
Originally Posted by Kwayz
I have no idea if this will actually work or not... Get one of the white Bic ink pens, take the little black cap off the non-writing end, push the (now) open end of the pen down into the lock and see if you can get it to turn (wiggle the big **** a bit while trying to turn the pen). The kind of pen I'm talking about is the kind of soft plastic one, white with black caps. The reason I suggest this is that I've heard that you can use those kinds of pens to "pick" a barrel lock, so it "might" work to get your lock back into the correct position.
Good luck!
Now, that's a scary proposition! I hope it's not that easy to unlock my bike's ignition and drive it off!!!
