ABS - yes or no?
ABS could save my life and that of my passenger.
Maybe with the exception of highly skilled riders and I even doubt they can, nobody can bring a non-ABS bike to a full stop as fast and as safely as an ABS bike, and this, on all terrains.
I would like to add at this point that ABS will more often not allow you to stop quicker, only to do so with more control over where and how you steer your vehicle.
If one knows it's there, and how to use it, it's a good thing. If you don't know how to use it, you can still run right into someone not realizing that you don't stop quicker, you just have better control because your not locked up.
The one time my cage's went off, I saw that I wasn't going to be able to stop before running into them, I steered away. You can't do that when your wheels are locked up. This is what ABS is really all about, continuous control.
Although it's a good thing for some, I prefer to go without. It's an expensive complicated system which is not understood by many, therefore dangerous in itself. If everybody understood the system and how it works it would be good all around, but most know not, therefore it becomes more dangerous.
Not just a personal opinion!
aka Bob
One thing I'd ask you, have you deliberately activated your bikes ABS? If not, I'd recommend you go find a nice vacant road or parking lot and play with it a little. Start with the rear brake only and speeds about 30 mph or so and work your way up. I did this on an empty street and ended up doing max effort stops from 60 to 65 mph on the rear brake alone, front brake alone, and finally both ends at the same time. It was a real eye opener and a great confidence builder, not to mention a lot of fun!
Ride Safe,
Steve R.
Pretty sure there is also an update for 08s because some folks were questioning if that was the fix when the 09 fix came out. Do a search on this forum to find the discussion and call your dealer because it made a big improvement on mine.
Beary
