No sound from stereo
Old Mar 29, 2010 | 08:06 PM
gillie64's Avatar
gillie64
Default check your fairing brackets
if you take the fairing off you better check your fairing brackets, all 4 of them. There is a good chance you have a broken one. The vibration causes damage to your radio, shuts it down. I used Iron cross and had great luck. MOCO can stick those brackets! there crap.
Old Mar 30, 2010 | 09:50 PM
20STREETGLIDE08's Avatar
20STREETGLIDE08
4th Gear
Default Update
Just to let everyone know what I have found out..... I checked all of the connections on the radio and amp and speakers and all seemed to be good. I hooked up new speakers and no fix. I eliminatedthe amp and speakers and hooked up new speakers straight from the head unit and nothing. Called the stealership and they told me to try two things....1) Turn the radio off by the power switch on the radio and wait five minutes before turning it back on. No fix 2) Unhook the battery and wait 20 minutes and try it again.No fix..They then told me to bring it in this weekend and more than likely the head unit is bad and would be replaced with a refurbished unit under warranty.
Old Mar 31, 2010 | 12:21 AM
roadgliderick's Avatar
roadgliderick
i have 09 streetglide and i had the 4th radio installed under warranty. these radios are **** so next week iam having alpine media deck installed my hk will be for sale if anyone is interested. its not a refurbished it is brand new. taken out of 2010 streetglide i played it once and havent used it again. iam not sure of the price yet but i did ask and these are $800.00 to $1000.00 for these shity *** radios. any way if anyone is interested let me know.
Old Mar 31, 2010 | 05:57 AM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
4 radios out of an 09...not time for a new radio, time for a new dealer. It's not the radio, it's a bike issue killing the radio. Seen this to many times to mention.
Old Jun 20, 2016 | 06:38 AM
bootcampsam's Avatar
bootcampsam
6th Gear
Default Stereo Problems
Originally Posted by 20STREETGLIDE08
I have a 2008 Street Glide that has an AM/FM/CD/WB stereo. I was riding the bike today listening to the radio. I got home pulled into the driveway and shut the bike off. Ten minutes later I started the bike back up and the radio display and all the controls work but there is NO sound at all. I can turn it to full volume and nothing. Not even a hiss, static or any sound. I tried turning the ignition to the assy position and I tried to turn just the radio off and back on and still nothing. Thank You in advance.
I know this is an old post but did you find out what the problem was? My Roadglide is having the same problem.
Old Jun 20, 2016 | 06:47 AM
Uncle Larry's Avatar
Uncle Larry
The OP hasn't been back since 2011 :>(
Old Jun 20, 2016 | 07:02 AM
Schex's Avatar
Schex
Eject the cd if there is one, set radio to fm, turn off ign switch, hold down any two soft keys 1-6, turn ign on to acc, continue holding until radio goes into diagnostic mode.
If dtc is present, it'll show up with a brief description.
A common failure is code b2017 LF speaker open, bad news is that it's most likely a problem inside the head unit
Old Jun 21, 2016 | 01:30 PM
rusty289's Avatar
rusty289
It sure sounds like vibration damage, that's what they do.
Call Iron Cross.
Old Jun 25, 2016 | 09:35 AM
470004's Avatar
470004
The same situation happen to me on my SG. All the functions worked on the head unit, but no sound. I thought it was the HD's amplifier. I bypass the amplifier and the head unit worked. I was lucky since a friend had another HD's amplifier he took off his bike and replaced it with a more powerful aftermarket amplifier. Hooked up the second HD's amplifier and I get the same crap. All functions working on the head unit, but no sound. Someone told me how to perform a self diagnostics test on the radio and it came up with " U1302-Infotainment Bus Off Error". Sent the head unit to Iron Cross Audio and they fix the problem. It turned out the "Infotainment Bus" in the head unit had shorted out and it was not reading the amplifier. I regards to re-flash the HU, I would s/w Iron Cross Audio first. I called the dealer before I s/w Iron Cross Audio and they told me I needed to re flash the HU. I s/w Iron Cross audio and they told me this was not the problem in my situation. Iron Cross Audio was correct.
Old Jun 25, 2016 | 02:33 PM
sbeast's Avatar
sbeast
if its under warranty, take it in to the dealership. if not, Go buy an aftermarket install kit and a marine head unit. basically any aftermarket unit will blow the stock HU away in terms of quality and functionality
Apr 20, 2016 01:32 PM
Napalm Dog
Oct 3, 2013 05:20 AM
fishtale
Jun 5, 2011 11:03 AM
williamfrog
Apr 30, 2010 06:12 PM
nemick
Aug 25, 2009 07:07 PM
