Oil Filter
Old Mar 29, 2010 | 08:49 PM
Teardrop's Avatar
Teardrop
Originally Posted by captjon37
I will stick with the stock filter myself. I like the K&N air filters but not the oil filters. Larger micron filtration. Got the cap for the filter at auto parts store. removal is easy.
I too will stick with the stock filter which was designed for the bike. I have had street bikes for 33+ years and have always used the OEM oil filters and have never had an issue.
Old Mar 29, 2010 | 09:18 PM
shagnasty's Avatar
shagnasty
Actually, K&N are made by Champion laboratories in the USA. The moco is going to use the cheapest bidder to make their filter just like they do their oil(CITGO currently). Do you really think a moco filter is the best? Probably not. K&N may not be the best, but it certainly isn't the worst. Do a internet search on them, there is a lot of info about filters out there.
Old Mar 29, 2010 | 09:21 PM
Gofer's Avatar
Gofer
I have found this http://www.calsci.com/motorcycleinfo...tml#OilFilters to be very helpful when researching an OIL FILTER for my scoot. If your interested at all about the best oil filter for your bike, this is a good page to start.
Old Mar 29, 2010 | 09:43 PM
Conehead's Avatar
Conehead
Found this on a site and thought it might help:
Hello,
When referring to particle sizes in regards to oil filters, it is important to realize exactly how small the particles being discussed really are. Then, we can discuss the filtration effects of the filters in question in regards to engine life. There is a misconception when it comes to oil filters, that the smaller the micron rating the better the filter. Some companies rate their filter as a “5 micron” filter, which means the filter will catch particles microns in size with at least 50% efficiency. Let’s put a 5 micron particle in perspective. 1 micron is .001mm (or .00003937 inch), so 5 micron is .005mm (.00019685 inch). The tolerances in your engine will be no smaller than 2.5 thousandths of an inch (.0025”). So, 2.5 thousands of an inch which is equal to a 63.5 micron particle. A 5 micron particle is smaller than a human red blood cell, and too small to see with the naked eye. So how can a particle that size cause damage to your engine?
Next, let’s consider the purpose of an oil filter bypass valve. A bypass valve opens when the inlet side of the filter gets too restrictive. This can happen when the engine is cold and the viscosity of the oil is high (due to the weight of the oil), but this primarily happens when the filter media gets too restrictive or clogged. This is done to keep catastrophic engine failure from occurring. The lower the pressure relief rating, the sooner the valve allows oil to bypass the filter. The last factor that contributes to the bypass opening is the amount (surface area) of the filter media used in the filter. A filter that has a high surface area is going to hold more contaminant and promote good oil flow for a longer period of time, so the bypass will take longer to open.
If the filter you use is 95% efficient at 5 microns it is going to remove more contaminant than a filter that is 3% efficient at 5 microns. The question is, how long will it take for those filters to load up with contaminant and enter bypass? The answer is simple, the more efficient filter will load up sooner, but at what expense? Oil flow is necessary to lubricate rotating parts and prevent engine failure, and dirty oil flow is better than starving the engine of oil completely (the theory behind the filter bypass). Clean oil is best for long engine life, and a filter that can promote clean oil flow consistently for a long period of time is a key component of any healthy engine.
When you are talking about filtration, whether it be oil or air, there is a balancing act that has to be performed to ensure your engine gets the protection it needs while giving your engine the most flow possible. Unfortunately, when the focus is an oil filter that is catching extremely small particles at a high percentage, the tradeoff is flow rate. This put the consumer in a “Catch-22” situation. Do you use a filter with the most efficient media at the smallest particle rating, and have the bypass open letting unfiltered oil through the system? Or do you have a filter that does not filter as small a particle size, but filters more of the oil for a longer period of time? K&N filters are designed to give you the balance of oil flow and filtration. Of course, we would like to say we have the most efficient filter at the smallest micron range, but the fact is we are not going to sacrifice oil flow or the quality of filtration by having a high efficiency filter that operates in bypass mode for 80% percent of its life. I know for me personally it’s a simple decision, the small particle filtration does not mean anything to me since we are talking about particles I can’t see, especially if there is a remote possibility of unfiltered oil touching my bearing surfaces causing premature wear and eventual engine failure.
When you are comparing filters, to make the most informed decision possible, look at the following things (with the least amount of emphasis on micron rating): Filtration efficiency, Filter surface area, bypass setting, micron rating.
The KN-171 filter has a nominal micron rating of 25, meaning it will capture 25 micron particles with at least 50% efficiency. The filtration efficiency of the KN-171 at 5 microns is 3%. The KN-171 also has 165 sq.in. of filter area, partially the reason it flows 25% better than the OE, paired with a bypass that opens at 14psi. The equivalent Harley Davidson filter is 95.8% efficient at 5 microns and 98.6% at 25 microns. It also has 63 sq.in. of media and a bypass that opens at 10psi. This means the Harley filter will run in bypass mode for a significant portion of its installed life, whereas the K&N will allow oil to flow through the filter for a longer period of time.
If you have any questions, please contact our Technical Support department.
Thanks for writing,
Thomas Walden
Technical Support & Sports Marketing
800-858-3333
ThomasW@KNFilters.com
Old Mar 29, 2010 | 09:50 PM
AlaskaAviator's Avatar
AlaskaAviator
I run Amsoil filters when I can get them.
Old Mar 29, 2010 | 10:03 PM
DeckerDude's Avatar
DeckerDude
Nice post Thomas
Old Mar 30, 2010 | 09:40 AM
Spur56's Avatar
Spur56
Hello,
This statement is misleading and not true. The bypass setting is a d/p so it is untrue that the 10 psid will be open most of the time. The normal filter d/p is well below 10 and therefore oil will flow through the media. The bypass is only there for a clogged filter to ensure no loss of flow to vital components. Please do not spread falsehoods for financial gain. Actually the K & N setting may be more dangerous by bypassing at a higher d/p. The fact is that K&N are great racing filters with high flow, they do not filter as good as Wix, Mobile 1 or Purolator. Use what you want as all are adequate, just don't use FRAM, too much cardboard.
Old Mar 30, 2010 | 10:50 AM
Iron Aces's Avatar
Iron Aces
We have K&P Engineerings Stainless Steel Micronic filter on both of our bikes and wouldn't go back to a standard paper filter even if someone paid us. The K&P is great because 1) you never have to replace it....when it's time to change the oil simply clean the filter, inspect for any damage and bolt back on 2) it provides up to 7% more oil flow 3) allows your oil to run cooler.
The downside is they are a bit pricing but considering you will never have to buy another one and the performance advantages, it's a no brainer in my opinion.
Lindsey :0)
Old Mar 31, 2010 | 06:23 PM
Conehead's Avatar
Conehead
I assume you are referring to the writer of the article in your statement about falsehoods? I don't know the first thing about oil filters just found the information and thought i would pass it along!
Old Mar 31, 2010 | 09:06 PM
Conehead's Avatar
Conehead
Originally Posted by DeckerDude
Nice post Thomas
Nope not Thomas, but I am sure you could e-mail him if you have a question.
Doug
TCMAN
Oil Archive (no new posts)
Sep 21, 2010 12:50 PM
Heritage123
Jul 9, 2010 11:44 AM
128auto
Jul 9, 2008 09:24 AM
rfp1954
Apr 7, 2008 01:27 PM
Lil Truckr
May 25, 2007 04:37 PM
